[mapserver-users] Removing collars on raster images
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Fri Aug 14 07:27:28 EDT 2009
I have not played with either lately. At least one difference is that gdal_merge.py can't warp images. Gdalwarp has also lots of more options. Long time ago I used modified gdal_merge.py first for creating a virtual raster file (.VRT) which I used later as input file for gdalwarp. Now there seems to be a separate tool for this purpose, gdalbuildvrt. Is even seems to acceps Mapserver tileindex files as input. I guess that if you'll select to make rectangular images with no nodata areas then the work chain would include (gdaltindex) - gdalbuildvrt - gdalwarp.
-Jukka Rahkonen-
Espen Isaksen wrote
> Yes, that is a solution that will probably work. Do you know
> the difference between gdal_merge.py and gdalwarp?
> Espen
> 2009/8/14 Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>:
> > Hi,
> > Not a very clever solution is to get rid of the collards
> forever. However, it works for sure. Select a rectangular
> grid in preferred output projection and mosaic and compress
> the original images to suit that grid with gdalwarp by using
> -te option. Then there will be no black borders to make
> transparent any longer. It does not mean much extra work if
> you have to compress the images in any case, but it does make
> updating image layer a bit more complicated if you will
> receice new images from scattered places every now and then.
> > -Jukka Rahkonen-
> >> -----Alkuperäinen viesti-----
> >> Lähettäjä: mapserver-users-bounces at lists.osgeo.org
> >> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Espen
> >> Isaksen
> >> Lähetetty: 14. elokuuta 2009 12:00
> >> Vastaanottaja: mapserver-users at lists.osgeo.org
> >> Aihe: [mapserver-users] Removing collars on raster images
> >> Hi!
> >> This question has been asked in different ways before, but the
> >> threads do not seem to give me the answers I need.
> >> We have lots of TB of images with black collars(borders). We would
> >> like to try out using Mapserver for serving these images,
> but we need
> >> to have the black collars transparent.
> >> That is fine in Mapserver as long at you use regular Tiff.
> >> However, because of the many TB of data we need to
> compress this data
> >> and preferably tiff with jpeg compression.
> >> However, this compression creates edges between the collar and the
> >> image where the image does not get transparent.
> >> I am struggling to find a solution to this problem. Is
> ideas on how
> >> we can avoid this problem? Is it for example possible to set a
> >> transparency mask in the Tiff image which can be used by Mapserver?
> >> Another solution would be if Mapserver could support
> setting an area
> >> in an image transparent based on a polygon file.
> >> Any help is appreciated.
> >> Espen
> >> _______________________________________________
> >> mapserver-users mailing list
> >> http://lists.osgeo.org/mailman/listinfo/mapserver-users
