[mapserver-users] Scaling Image Symbol Offset
Havard Tveite
havard.tveite at umb.no
Fri Aug 14 08:01:01 EDT 2009
Dear Steve,
Is this another case for allowing the user to explicitly specify
the centre of a symbol (as proposed in RFC 45 -
http://mapserver.org/development/rfc/ms-rfc-45.html)?
Håvard
Steve Lime wrote:
> Hi David: There is no connection between offset and symbol size. The offset is independent and given
> as a constant value in pixels (although it is scaled). Sounds like you need to change it dynamically based
> on your image size and that can't be done as things sit now. Can you fix your image size or is it and I'm
> missing something.
> Steve
>>>> On 7/16/2009 at 3:51 AM, in message
> <9C37154DC7C8074FBC34214363755B7C33087F at ITB-SVR-01.itbeyond.local>, "David
> Martin" <David at itbeyond.com.au> wrote:
>> I am developing a new application and am rendering around a load of
>> graphic symbol layers using a Map file layer such as
>> LAYER
>> NAME cape_headland_point
>> STATUS ON
>> GROUP all
>> DATA 'ExplorOz/Places/Cape,Headland,Point'
>> TYPE POINT
>> SYMBOLSCALE 1000000
>> CLASS
>> STYLE
>> SYMBOL [POIImage]
>> MAXSIZE 15
>> MINSIZE 4
>> SIZE 8
>> END
>> END
>> METADATA
>> "wms_title" "Capes, Headlands & Points"
>> END
>> PROJECTION
>> "+proj=longlat +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +no_defs"
>> END
>> END
>> As you can see I am sizing the output symbol which is a 20x20px PIXMAP
>> image - this is working great however the position of the image needs to
>> be OFFSET up by half the size of the image (to make the actual point be
>> the center of the image) - I have tried using OFFSET however when the
>> image size changes (based on SYMBOLSCALE)the offsets are wrong. Is there
>> a way to OFFSET image symbols based on the SYMBOLSCALE and MAX/MIN
>> SIZES?
>> Regards
>> David
> mapserver-users at lists.osgeo.org
Håvard Tveite
Department of Mathematical Sciences and Technology, UMB
Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
