VS: [mapserver-users] Tileindex and drawing order of overlapping
images
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Fri Aug 14 08:44:42 EDT 2009
Frank Warmerdam wrote:
Rahkonen Jukka wrote:
>> Hi,
>> If have overlapping images from different years. Can I control in some
>> easy and reliable way that the new images will get drawn on top, for
>> example by writing tileindex shapefiles so that new images have bigger
>> fid values?
>Jukka,
> The order of images in the tileindex shapefile will be the order
> they are drawn - if - you do not build a spatial index on the
> shapefile. If you have a spatial index the drawing order
> becomes essentially random, and of course if you have a lot
> of images a spatial index is quite valuable.
Damn, I need spatial index for sure. Any idea about how to get them both? Perhaps taking tile index with ordered query from Oracle, PostGIS or even SpatiaLite?
-Jukka-
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
