[mapserver-users] How to Check if MapScript is Enabled?
Andy Colson andy at squeakycode.net
Wed Aug 19 14:37:29 EDT 2009
Bill Thoen wrote:
> I want to take a look at dLegend in the dBox package but dBox (and
> presumably dLegend)  requires either Perl or Python mapscript to be
> installed with MapServer. I've forgotten how to check if, or which,
> mapscript is installed. When I try ./mapserv -v from the cgi-bin
> directory, mapscript isn't among the results, but I don't know if this
> means it's not installed or if I need to use another method to determine
> the mapscript availability. I probably wouldn't have installed a Perl
> version and definitely wouldn't install a Python version because I don't
> know these environments well. I don't remember if I tried the PHP
> version., but I'm not finding any evidence that PHP mapscript is
> installed either. I just want to know how to make sure what's in and
> what's not.
> I'd appreciate any suggestions you can offer.
> Thanks,
> - Bill Thoen
> mapserver-users at lists.osgeo.org
The program mapserv is not required for mapscript.  To find out if its
in php, view the php info, which is easiest with a page like:
<?PHP
    echo phpinfo();
To see if its in perl, at a command line, type:
perl -Mmapscript -e ''
if nothing happens, your golden, otherwise you'll get an error saying it
cant locate mapscript.pm.
dunno about python.
-Andy
