[mapserver-users] Class level Transparency/Opacity
Varun saraf
vsaraf.gmu at gmail.com
Wed Aug 19 16:02:06 EDT 2009
Hello,
Is it possible to set a transparency rate for the CLASS level Color?
Below is my mapfile. I am using this layer on google maps in tile
mode. When I do so, the base map is getting completely overlapped by
the colored polygons. I need a level of transparency so that the base
map's roads and location are visible. In other words, I only want to
highlight the polygons that match the expression criteria. Can someone
tell me what I need to do for the same? I have already tried putting
in OPACITY field in the layer object but it only lightens the color
without making it transparent. an OPACITY of 1 renders the polygons
"white" in color.
MAP
NAME drawBothMap
TRANSPARENT ON
IMAGETYPE PNG
PROJECTION
"init=epsg:4326"
END
LAYER
NAME "USABOTH"
STATUS DEFAULT
METADATA
wms_title "example_layer"
END
TYPE polygon
DATA USA
CLASSITEM "QCT"
CLASS
EXPRESSION '1'
COLOR 255 0 0
END
CLASS
EXPRESSION '2'
COLOR 0 255 0
END
CLASS
EXPRESSION '3'
COLOR 0 0 255
END
END
END
Thanks,
Varun
