[mapserver-users] Export / Print Map to PDF
Brian Fischer bfischer at houstoneng.com
Thu Aug 20 15:46:44 EDT 2009
The GeoMOOSE project also uses FPDF to export a map to pdf.  There is a print.php script in the source code that would give you some ideas on how it is done.  It also supports printing markups drawn on the map.
Here's the help page for it http://www.geomoose.org/moose/howto/print_template.html
Hope this helps,
Brian
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of HeiJo
Sent: Thursday, August 20, 2009 2:06 AM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Export / Print Map to PDF
And you can use FPDF or UPDF for a further PDF file creation. Take notice of
font issue.
Refer to PMapper mapping software ( http://www.pmapper.net ) for an
excellent exam.
View this message in context: http://n2.nabble.com/Export---Print-Map-to-PDF-tp3456688p3477325.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
