[mapserver-users] Mapscript Strange behaviour of drawQuery
Thomasch thomaschx at gmx.de
Sun Aug 23 08:14:29 EDT 2009
I'm using Mapserver 5.2.1 on WinXP.
If I try to draw a query using drawQuery() the scale of my map is
changed - even if the qurery returns no result. If I don't draw the
query, everyting is fine.
Please see my code in Attachement.
Is there a workaraund?
Thank you
Thomasch
MAP
  EXTENT 12.4321 51.1277 12.439334 51.168119
  FONTSET "fonts/fonts.list"
  TEMPLATEPATTERN "test"
  IMAGECOLOR 215 215 215
  IMAGETYPE png
  SHAPEPATH "C:/Programme/ms4w/apps/Test/data"
  SIZE 400 400
  STATUS ON
  UNITS DD
  CONFIG MS_ERRORFILE "C:/Programme/ms4w/tmp/ms_error.txt"
  NAME "Test4"
  OUTPUTFORMAT
    NAME "png"
    MIMETYPE "image/png"
    DRIVER "GD/PNG"
    EXTENSION "png"
    IMAGEMODE "PC256"
    TRANSPARENT FALSE
  END
  PROJECTION
    "init=epsg:4326"
  END
  QUERYMAP
    COLOR 255 255 0
    SIZE 260 210
    STATUS ON
    STYLE HILITE
  END
  WEB
    FOOTER "footer.html"
    HEADER "header.html"
    IMAGEPATH "C:/Programme/ms4w/tmp/ms_tmp/"
    IMAGEURL "/ms_tmp/"
    LOG "C:/Programme/ms4w/log/mslog/log.txt"
    QUERYFORMAT text/html
    LEGENDFORMAT text/html
    BROWSEFORMAT text/html
    TEMPLATE "basic.html"
  END
  LAYER
    CLASSITEM "orte"
    DATA "orte"
    DUMP TRUE
    FOOTER "TP_footer.html"
    HEADER "TP_header.html"
    LABELITEM "orte"
    METADATA
      "qstring_validation_pattern"	"."
    END
    NAME "orte"
    STATUS ON
    TOLERANCE 0
    TYPE POLYGON
    UNITS METERS
    CLASS
      NAME "orte"
      LABEL
        SIZE MEDIUM
        TYPE BITMAP
        BUFFER 2
        COLOR 0 0 0
        FORCE FALSE
        MINDISTANCE -1
        MINFEATURESIZE -1
        OFFSET 0 0
        PARTIALS TRUE
        POSITION CC
        SHADOWCOLOR 218 218 218
        SHADOWSIZE 2 2
      END
      STYLE
        ANGLE 360
        COLOR 232 252 232
        OPACITY 100
        OUTLINECOLOR 32 32 32
        SYMBOL 0
      END
      TEMPLATE "TP.html"
    END
  END
END
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090823/e3c1df21/test4.html
