[mapserver-users] Any pointers on calculating the shortest route
between 2 points?
Adrian Popa
adrian_gh.popa at romtelecom.ro
Mon Aug 24 08:58:54 EDT 2009
Thank you both,
I wasn't aware of it. I will look into it.
Regards,
Adrian
Stephen Woodbridge wrote:
> Adrian,
> Look at pgRouting. http://pgrouting.postlbs.org/
> -Steve
> Adrian Popa wrote:
>> Hello everybody,
>> Sorry if this question is not specific to mapserver, but I was
>> wondering if I could get some pointers on where to start with this
>> problem.
>> So, I have a layer with street numbers for some cities, and I want to
>> be able to display the route between 2 such points. I've done
>> something similar in the past by using Boost (as a perl module) and
>> loading the network as a graph and using Dijkstra algorithm to
>> calculate the shortest path between 2 points. The problem is - the
>> data I had clearly defined the nodes of the graph (vertexes) and the
>> edges (links) between the nodes, so I was able to easily build the
>> graph and interpret the results.
>> The data I have now looks like this (for a record):
>> OGRFeature(Streets_geocoding):1123
>> Name (String) = West St
>> FromLeft (Integer) = 3
>> ToLeft (Integer) = 5
>> FromRight (Integer) = 12
>> ToRight (Integer) = 32
>> Link_ID (Real) = 588532637
>> Judet (String) = TIMIS
>> Localitate (String) = TIMISOARA
>> L_PostCode (String) = 300609
>> R_PostCode (String) = 300609
>> Style = PEN(w:2px,c:#ff00ff,id:"mapinfo-pen-2.ogr-pen-0")
>> LINESTRING (21.17921 45.751309999999997,21.18102 45.753790000000002)
>> The problem is I have lots of small links (street segments) but
>> without an obvious way to link them together (maybe Link_ID is
>> something useful - I'll look into it).
>> My question is: In your opinion - how is "routing" implemented on
>> maps (e.g. on GPS receivers) - Do the maps have special information,
>> or should I manage with what I have?
>> Any pointers are helpful, thanks
>> Regards,
>> Adrian
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
