[mapserver-users] drawEPP(): EPPL7 support is not available
Antonio Volpix
antonio.mailinglist at gmail.com
Mon Aug 24 19:15:29 EDT 2009
On Mon, Aug 24, 2009 at 9:50 PM, Frank Warmerdam <warmerdam at pobox.com>wrote:
> Antonio Volpix wrote:
>> Hi,
>> I am spending a lot of time to resolve this issue.
>> I run a lot of WMS requests to mapserver always on the same mapfile and
>> same layer.
>> Some time, and I don't understand why , mapserver return me the error in
>> the subject.
>> The error is localized always in a specific area , it isn't random.
> Antonio,
> Is the problem reliably repeatable with a particular request?
Yes , always in that area it gives me the same error. But if I use a BBOX
with a smaller range keeping the same tilesize (256x256) it works fine (
not always)
I am running WMS requests to generate a 256x256 tiles at different zoom
levels.
> Does you have a tiled raster layer in your map file?
Yes I have about 28000 images , .gif with a .wld associated.
> The error generally means that a raster file was not able to be opened
> with any of the provided mechanisms. Generally speaking it should be
> GDAL that opens the file, but it would seem that for some file (at least
> sometimes) GDALOpen() is failing.
> It may be helpful to enable GDAL debug output, especially if you can narrow
> things down to a particular request the triggers it. This should be
> accomplishable in the MAP file by adding this line within the MAP object:
> CONFIG "CPL_DEBUG" "ON"
OK , I set up this option in the map file but where have I to check the
error ?
Thanks for your quickly response.
Antonio
> Alternatively set this as an environment variable in a mapserv cgi wrapper
> script.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam<http://pobox.com/%7Ewarmerdam>
> and watch the world go round - Rush | Geospatial Programmer for Rent
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090825/f5c00593/attachment-0001.html
