[mapserver-users] Mapscript Strange behaviour of drawQuery
Thomasch thomaschx at gmx.de
Tue Aug 25 10:18:29 EDT 2009
I set the ectends before the query. But I found, that's possible to draw
the querymap instead of the "normal" map like the GMap demo does. So I
didn't deal with this case any longer.
Thomasch
Steve Lime wrote:
> It's possible that the query functions themselves are mucking with the
> map extent. Did you try:
>   1) printing the extent before and after the query?
>   2) expressly setting its value to what you expect before calling drawQuery?
> Steve
>>>> Thomasch <thomaschx at gmx.de> 08/23/09 7:15 AM >>>
> Hi,
> I'm using Mapserver 5.2.1 on WinXP.
> If I try to draw a query using drawQuery() the scale of my map is
> changed - even if the qurery returns no result. If I don't draw the
> query, everyting is fine.
> Please see my code in Attachement.
> Is there a workaraund?
> Thank you
> Thomasch
