SV: SV: [mapserver-users] Mapserver consuming Google Maps
Niels-Peter Jensen
npj at i-gis.dk
Wed Aug 26 03:54:02 EDT 2009
Hi Till
I see the google maps tiles as a way of getting a free basemap. You are
properly right regarding distroted labels when reprojecting googlemaps -
depending on where you are in the world and the final projection. But at
least a pure sattelite image would ok.
I could make a client to consume both Mapserver and Googlemaps, but I would
like to do it on the server side and be able to use MapServer features, eg.
turning on/off layers, changing order of layers and so on.
Regards Niels-Peter
-----Oprindelig meddelelse-----
Fra: Till Adams [mailto:adams at terrestris.de]
Sendt: 26. august 2009 09:21
Til: Niels-Peter Jensen
Cc: mapserver-users at lists.osgeo.org
Emne: Re: SV: [mapserver-users] Mapserver consuming Google Maps
Niels-Peter,
I really do not see the need for this.
All things, which are fun regarding Mapserver are not possible with
GoogleMaps, e.g. reprojection or define your map layout in an easy way.
Even if you would write some piece of code, which would enable mapserver
getting that google tiles as a datasource you'll have at least a slower
service than pure google and - if reprojecting the google stuff - you'll
have "unreadable" maps with distorted labels.
So beside the fact Chris already mentioned - I think if you have a
client, which is able to show Mapserver services AND google map services
together, you're fine, or what is your intention?
Regards, Till
> Yes, it could be a violation of terms, but not if the copyright notice
> and links still is there - or am I wrong on that ? At least, thats
> this is what the Openlayers community thinks. I think it would be a
> very nice if that could be accomplished with MapServer too.
> Niels-Peter
> Fra: Christopher Schmidt [mailto:crschmidt at metacarta.com]
> Sendt: 25. august 2009 17:14
> Emne: Re: [mapserver-users] Mapserver consuming Google Maps
> On Tue, Aug 25, 2009 at 04:42:27PM +0200, Niels-Peter Jensen wrote:
>> Hi mapserver users
>> Does anybody know if there has been done work to let MapServer
>> consume
>> Google maps ? I know that this is possible in OpenLayers (an example:
>> http://openlayers.org/dev/examples/google.html), but with MapServer I can
>> only se it the other way around, MapeServer serving maps til a GoogleMaps
>> application by WMS.
> Doing so would be a violation of the terms of use of Google Maps.
> Regards,
terrestris GmbH & Co. KG
Irmintrudisstrasse 17
53111 Bonn
Germany
Till Adams
Geschäftsführung
Tel: +49 (0)228 / 962 899-52
Fax: +49 (0)228 / 962 899-57
adams at terrestris.de http://www.terrestris.de
Amtsgericht Bonn, HRA 6835
Komplementärin:
terrestris Verwaltungs GmbH
vertreten durch:
Hinrich Paulsen, Till Adams
No virus found in this incoming message.
Checked by AVG - www.avg.com
Version: 8.5.409 / Virus Database: 270.13.65/2324 - Release Date: 08/25/09
18:07:00
