[mapserver-users] Variable-substitution cause WMS
GetFeatureInfo error
Stephan Holl
stephan.holl at intevation.de
Thu Aug 27 04:52:22 EDT 2009
Hello AlessioDL,
AlessioDL <alessio.dilorenzo at gmail.com>, [20090827 - 03:41:33]
> I post the my code... hope this "helps to help" :-)
> Mapfile layer:
> LAYER
> NAME "QueryAreas"
> TYPE POLYGON
> CONNECTIONTYPE postgis
> CONNECTION "host=localhost
> user=***password=*** dbname=***"
> DATA "the_geom FROM (SELECT * FROM areas)AS
> foo USING UNIQUE gid USING SRID=4326" FILTER
> "YEAR = %YEAR%" METADATA
> "wms_title"
> "Query Areas"
> "wms_include_items" "all"
> "wms_exclude_items" "the_geom" END
> DUMP TRUE
> STATUS ON
> TRANSPARENCY ALPHA
> CLASS
> TEMPLATE
> "../TemplateMS/areas.html" NAME "Areas"
> STYLE
> SYMBOL "simpleline"
> SIZE 2
> OUTLINECOLOR 0 0 0
> COLOR 255 127 36
> END #Style end
> END #Class end
> END #Layer end
> OpenLayers code:
> [code]
> var map, qAreas, year;
> var wmsURL =
> "http://correggiov3/cgi-bin/mapserv.exe?map=/ms4w/apps/caps_manager/Mapfiles/wms.map";
> var cgiURL = "http://correggiov3/cgi-bin/mapserv.exe?";
> var proj4326 = new OpenLayers.Projection("EPSG:4326");
> var proj900913 = new OpenLayers.Projection("EPSG:900913");
> function initMap(){
> OpenLayers.IMAGE_RELOAD_ATTEMPTS = 3;
> OpenLayers.Util.onImageLoadErrorColor = "transparent";
> startBounds = new
> OpenLayers.Bounds(1297594.634132,5197717.568058,2178149.1998195,5818997.7338486);
> options = {
> controls:[],
> projection: new OpenLayers.Projection("EPSG:900913"),
> displayProjection: new OpenLayers.Projection("EPSG:4326"),
> units: "m",
> numZoomLevels: 18,
> maxResolution: 156543.0339,
> maxExtent: new
> OpenLayers.Bounds(-20037508,-20037508,20037508,20037508.34)
> map = new OpenLayers.Map('map', options);
> // create Google Mercator Layers
> var gphy = new OpenLayers.Layer.Google("Google Terrain",{type:
> G_PHYSICAL_MAP, 'sphericalMercator': true});
> var gmap = new OpenLayers.Layer.Google("Google
> Streets",{'sphericalMercator': true});
> var gsat = new OpenLayers.Layer.Google("Google Satellite",{type:
> G_SATELLITE_MAP, 'sphericalMercator': true});
> var ghyb = new OpenLayers.Layer.Google("Google Hybrid",{type:
> G_HYBRID_MAP, 'sphericalMercator': true};
> // add Layers array
> map.addLayers([gphy,gmap,gsat,ghyb]);
> // add simple Controls
> map.addControl(new OpenLayers.Control.LayerSwitcher());
> map.addControl(new OpenLayers.Control.MousePosition(/*{div:
> $('coord')}*/));
> map.zoomToExtent(startBounds);
> * GetFeatureInfo - Pupup
> var info = new OpenLayers.Control.WMSGetFeatureInfo({
> url:
> "http://correggiov3/cgi-bin/mapserv.exe?map=/ms4w/apps/caps_manager/Mapfiles/wms.map",
> title: 'Identify features by clicking',
> queryVisible: true,
> eventListeners: {
> getfeatureinfo: function(event) {
> map.addPopup(new OpenLayers.Popup.FramedCloud(
> "chicken",
> map.getLonLatFromPixel(event.xy),
> null,
> event.text,
> null,
> true
> map.addControl(info);
> info.activate();
> } //end initMap
> * Add the filtered layer
> function addQueryLayers(){
> year = document.forms['queryForm'].elements["year"].value;
> areaType =
> document.forms['queryForm'].elements["areaType"].value;
> qAreas = new OpenLayers.Layer.WMS("Selected areas", wmsURL, {
> map:"/ms4w/apps/caps_manager/Mapfiles/wms.map",year:year,
> layers: 'QueryAreas',
> format:'image/png',
> transparent:'true'
> }, {'isBaseLayer':false});
> map.addLayer(qAreas);
> [/code]
I cannot see the Variable year passing to the getfeatureInfo-Request.
You should verify if the getfeatureinfo-request ist built correct by
openlayers. Using a handcraftet getfeatureinfo-request with the
filter-attribute should work.
HTH
Stephan
Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33 508 3663
Intevation GmbH, Neuer Graben 17, 49074 OS | AG Osnabrück - HR B 18998
Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090827/f31f542e/signature.bin
