[mapserver-users] layers not getting separated
sunny74
sb.ray at hotmail.com
Fri Aug 28 07:45:04 EDT 2009
Thanks for your reply.
My problem is solved.
Problem was in the map file.The status of each layer was "DEfault", so all
the layers were loading and not turning off.Then I changed the status of all
except the base to "OFF".I found that it was turning on and off.
But now I am having another issue.I have 12 layers in my map and it is
taking tooooo long to load.Therefore I decided to turn on only 2 layers at
Page Load.
Rest of the layers I want to turn on at a particular zoom level.How can I
check the zoom level and turn on these layers.
Thanks for ur reply.
Steve.Toutant wrote:
> and your mapfile as well?
> Steve Toutant, M. Sc.
> Analyste en géomatique
> Secteur environnement
> Direction des risques biologiques, environnementaux et occupationnels
> Institut national de santé publique du Québec
> 945, avenue Wolfe
> Québec, Qc G1V 5B3
> Tél.: (418) 650-5115 #5281
> Fax.: (418) 654-3144
> steve.toutant at inspq.qc.ca
> http://www.inspq.qc.ca
> Pavel Iacovlev <iacovlev.pavel at gmail.com>@lists.osgeo.org
> Envoyé par : mapserver-users-bounces at lists.osgeo.org
> 26/08/2009 09:35 AM
> A
> sunny74 <sb.ray at hotmail.com>
> cc
> mapserver-users at lists.osgeo.org
> Objet
> Re: [mapserver-users] layers not getting separated
> Can we see your OpenLayers JS code ?
> On Wed, Aug 26, 2009 at 3:46 PM, sunny74<sb.ray at hotmail.com> wrote:
>> Dear Friends,
>> I am displaying a map using mapserver and openlayers.The map is
> displayed
>> using a map file kept within a folder containing shape files.
>> Although the map is getting displayed, if I add more than one layer the
>> layers are not getting separated.
>> i.e I can see the layer in the Layer switcher but if I check or uncheck
>> nothing happens.
>> This means all the layers are coming as a single image.
>> I feel that there is something in the map file which I have ommitted and
> so
>> this happens.
>> I used QGIS to create the map file.
>> Looking for a solution.
>> Thanks for your replies.
>> View this message in context:
> http://n2.nabble.com/layers-not-getting-separated-tp3514899p3514899.html
>> Sent from the Mapserver - User mailing list archive at Nabble.com.
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> http://iap.md, The future is open
View this message in context: http://n2.nabble.com/layers-not-getting-separated-tp3514899p3534120.html
