[mapserver-users] Postgis tile index not working
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Aug 31 09:01:00 EDT 2009
Nelson Correia wrote:
> Hi,
> I'm trying to use a postgis layer as tile index of a raster layer and
> can't get it working.
> Here are the layers I'm using:
> LAYER
> NAME "layer_tindex"
> TYPE POLYGON
> CONNECTIONTYPE POSTGIS
> CONNECTION "host=localhost port=5432 dbname=mydb
> user=myuser password=mypwd"
> DATA "bbox from shapes"
> CLASS
> STYLE
> OUTLINECOLOR 0 0 0
> END
> END
> END
> LAYER
> NAME "layer_raster"
> TYPE RASTER
> STATUS DEFAULT
> DUMP TRUE
> TILEINDEX "layer_tindex"
> TILEITEM "image_path"
> PROJECTION
> "init=epsg:4326"
> END
> END
> When I make a request to Mapserver, everything gets into the image,
> except the images from the "layer_raster" layer. I can even see the
> bboxes if I turn on the layer "layer_tindex".
> I can't find much documentation about this integration between Mapserver
> and Postgis, so tell me if I'm making some mistake.
> By the way, I'm doing this with a Mapserver 5.2.1.
> Thanks in advance,
I would start by using the commandline utility shp2img with the
'-all_debug 3' switch to see all errors (example#3 on
http://www.mapserver.org/utilities/shp2img.html).
-jeff
Jeff McKenna
FOSS4G Consulting and Training Services
http://www.gatewaygeomatics.com/
