[mapserver-users] Fatal error: Call to undefined function dl()
in C:\ms4w\Apache\htdocs\phpmapscript.php on line 5
new
geetha at ttkmaps.com
Tue Dec 1 01:51:43 EST 2009
Thanks milo,
I checked with php.ini dl method is enabled.I tried in commmand prompt
php C:/ms4w/Apache/htdocs/phpmapscript.php
No windows error was reported.
newuser.
Milo van der Linden-3 wrote:
> Dear geetha,
> This has nothing to do with mapserver/mapscript, but is a php error. The
> dl method is (correct me if I am wrong) a little outdated and has to
> specifically be set to ENABLED in the php.ini.
> Please google a bit on the dl error and see what parameter you need to
> change (sorry that I cannot give you a full answer, but I am on 3G in a
> train and unable to do some serious googlin')
> On Tue, 2009-12-01 at 00:37 -0500, geetha at ttkmaps.com wrote:
>> Hi all,
>> I tried to install php/mapscript in windows,I get the above error.I
>> use mapserver version 5.4.2,Apache 2.2.11,PHP 5.3.Php works fine.Im
>> able to run files with .php extension,but the below coding produces
>> error:
>> <HTML>
>> <BODY>
>> <?php
>> dl("php_mapscript.dll");
>> phpinfo();
>> </BODY>
>> </HTML>
>> My php_mapscript.dll is in ..php/ext folder by default.My php.ini &
>> php.exe is in /ms4w/Apache/cgi-bin.Is there any other dll i should
>> add?It is said php/mapscript is preconfigured right...then what might
>> be wrong?Thanks in advance.
>> NewUser.
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
View this message in context: http://n2.nabble.com/Fatal-error-Call-to-undefined-function-dl-in-C-ms4w-Apache-htdocs-phpmapscript-php-on-line-5-tp4092107p4092227.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
