[mapserver-users] WMS: raster's x and y pixel dimension
fla83tn at libero.it
Tue Dec 1 09:06:35 EST 2009
Hi to all,
I've a problem with the loading of a raster image via WMS (1.3.0).
To load the layers of my project I use gvSIG. If I load my digital elevation
model (DEM) directly from filesystem (which is a HFA/Erdas Image file - .img),
x and y pixel dimension are fixed to 2.5 and -2.5 meters respectively, and
fixed are also the width and height attributes.
If I load the layer from
Mapserver's WMS instead, x and y pixel dimension change as I zoom in or out (i.
e. changing the width
and height parameters of the getMap request).
Is there
the possibility to tell the wms client that x and y pixel dimension are
constant and should never be calculated?
Here's my layer definition and the
tiff outputformat definition:
OUTPUTFORMAT
NAME GTiff
DRIVER "GDAL/GTiff"
MIMETYPE "image/tiff"
IMAGEMODE FLOAT32
EXTENSION "tif"
END
LAYER
NAME
"my_dem"
EXTENT 669913.75 5143998.75 678313.75 5150701.25
METADATA
"wms_title" "my_dem" ##required
"wms_extent" "669913.75 5143998.75
678313.75 5150701.25"
"gml_include_items" "all"
END
TYPE RASTER
STATUS ON
PROJECTION
"init=epsg:25832"
END
DATA "my_dem.tiff"
PROCESSING "NODATA=-9999"
PROCESSING "SCALE=227.23,1741.15"
PROCESSING
"SCALE_BUCKETS=2000"
PROCESSING "BANDS=1"
DEBUG on
DUMP true
TEMPLATE "void" # enable queryable attribute on the layer
END
Any help is
appreciated,
Flavio
