[mapserver-users] WMS: raster's x and y pixel dimension
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Tue Dec 1 16:33:42 EST 2009
I would say that the main difference is that WMS is meant for showing a map on a computer screen, while WCS is made for letting users to download data so they can utilise it locally or process further. Real life is not so black and white. I promise you will find lots of good reading about WMS and WCS easily. Do not forget to read a little bit about WFS as well, service for downloading vector data.
-Jukka Rahkonen-
fla83tn wrote:
Lähetetty: ti 1.12.2009 17:31
Vastaanottaja: Rahkonen Jukka; mapserver-users at lists.osgeo.org
Aihe: Re: Re: [mapserver-users] WMS: raster's x and y pixel dimension
Thank you Jukka for the quick reply. Now I'm able to correctly generate z-
dimension from DEM layer.
However, since I'm new to GIS, I'm not able to
understand the differences between WCS and WMS..could
you briefly summarize
the goal of the two approach?
And, as last question , should I set the resX and
resY parameters from client or could I embed them directly into the map file?
Best regards,
Flavio
>Hi,
>Width, height and BBOX are all compulsory
parameters in WMS GetMap
>request and Mapserver is sending an image according
to the request. If
>you want to be able to control the pixel size easily,
without making WMS
>client to balance the BBOX and image size in pixels,
consider using WCS.
>One way to make a WCS request is
>http://server.fi/cgi-
bin/mapserver_wcs?SERVICE=WCS&VERSION=1.0.0&REQUEST
>=GetCoverage&COVERAGE=DEM&FORMAT=image/tiff&CRS=EPSG:3067&ResX=1.0&ResY=
>1.
0&BBOX=533652,6973434,534658,6974219
>You can see parameters ResX and ResY
which are used for controlling the
>pixel size.
>-Jukka Rahkonen-
>fla83tn
wrote:
>> Hi to all,
>> I've a problem with the loading of a raster
image via WMS (1.3.0).
>> To load the layers of my project I use gvSIG. If
I load my
>> digital elevation model (DEM) directly from filesystem (which
is a HFA/Erdas Image file - .img),
>> x and y pixel dimension are fixed to
2.5 and -2.5 meters
>> respectively, and fixed are also the width and height
attributes.
>> If I load the layer from
>> Mapserver's WMS instead, x and y
pixel dimension change as I
>> zoom in or out (i.
>> e. changing the width
and height parameters of the getMap request).
>> Is there
>> the possibility
to tell the wms client that x and y pixel
>> dimension are constant and should
never be calculated?
>> Here's my layer definition and the
>> tiff
outputformat definition:
>> OUTPUTFORMAT
>> NAME GTiff
>> DRIVER
"GDAL/GTiff"
>> MIMETYPE "image/tiff"
>> IMAGEMODE FLOAT32
EXTENSION "tif"
>> END
>> LAYER
>> NAME
>> "my_dem"
>> EXTENT 669913.75
5143998.75 678313.75 5150701.25
>> METADATA
>> "wms_title"
"my_dem" ##required
>> "wms_extent" "669913.75 5143998.75
>> 678313.75
5150701.25"
>> "gml_include_items" "all"
>> END
>> TYPE RASTER
STATUS ON
>> PROJECTION
>> "init=epsg:25832"
>> END
DATA "my_dem.tiff"
>> PROCESSING "NODATA=-9999"
>> PROCESSING
"SCALE=227.23,1741.15"
>> PROCESSING
>> "SCALE_BUCKETS=2000"
>> PROCESSING
"BANDS=1"
>> DEBUG on
>> DUMP true
>> TEMPLATE "void" # enable
queryable attribute on the layer END
>> Any help is
>> appreciated,
Flavio
>> mapserver-users
>> http://lists.osgeo.
org/mailman/listinfo/mapserver-users
