[mapserver-users] Reprojection from ETRS89 to ED5030
Till Adams
adams at terrestris.de
Wed Dec 2 09:47:37 EST 2009
David,
did you define the epsg the WMS should be valid for in the wms metadata
section ?
Should be like this:
'WMS_SRS' 'epsg:23030 epsg:25830'
If you have the direct getMap request and you didn't do the above,
mapserver reports an error like
"projection library error. no system list,errno: 2"
Regards, Till
> Hi everyone!
> I have some problems to reproject WMS service from ETRS89 to ED5030 in tools
> like ArcGis or gvSIG. I´ve defined all the layers with PROJECTION 25830
> (ETRS89).
> As majority knows there is an internal mapserver´s file called epsg
> (\ms4w\proj\nad) where It´s possible to define diferents reprojections. The
> definition line to define reprojection from ED5030 to ETRS89 is the
> following one in my server:
> <23030> +proj=utm +zone=30 +ellps=intl +towgs84=-87,-98,-121,0,0,0,0
> +units=m +nadgrids=sped2et.gsb +no_defs <>
> Therefore I suppose I have to change this line to inverse reprojection (from
> ETRS89 to ED5030):
> <25830> +proj=utm +zone=30 +ellps=GRS80 +units=m +no_defs <>
> ,but I have no clue about it.
> Any ideas?
> Thanks in advance.
> David
terrestris GmbH & Co. KG
Irmintrudisstrasse 17
53111 Bonn
Germany
Till Adams
Geschäftsführung
Tel: +49 (0)228 / 962 899-52
Fax: +49 (0)228 / 962 899-57
adams at terrestris.de http://www.terrestris.de
Amtsgericht Bonn, HRA 6835
Komplementärin:
terrestris Verwaltungs GmbH
vertreten durch:
Hinrich Paulsen, Till Adams
