[mapserver-users] mapscript does not use GRID information when reprojecting rect object
francesco francesco.pirotti at unipd.it
Mon Dec 7 05:50:51 EST 2009
Hello I do not know if this it the right list to post, but I was
wandering if any of you had trouble when using the "project()" function
in mapscript (PHP). It does not use the grid file which is stated in the
EPSG line in the epsg file inside the ...proj/nad directory.
Reprojection of the map is wonderful, uses the grids, but script
reproject of a rectangle object does not make use of the grids. I made
sure of course that the epsg file which is read is the one I modified.
Anyone had the same problem?
*Francesco Pirotti*
CIRGEO – Interdepartmental Research Center on Cartography Photogrammetry
Remote Sensing and G.I.S.
University of Padova
Web: http://www.cirgeo.unipd.it/cirgeo/francescopirotti.htm
Email: francesco.pirotti at unipd.it <mailto:francesco.pirotti at unipd.it>
Phone: +39 049 827 2710
Phone: +39 349 55 39 261
