[mapserver-users] Re: Mapserver WMS under IIS 7 x64 serving up	blank images
    Daniel Walton
    dgwalton at gmail.com
    Mon Dec  7 12:00:00 PST 2009
Update: Same problem happens with the x86 binaries all other things being
equal. Also, I have trimmed the set of files in my mapserver binary folder
to these:
epsg
fribidi.dll
gdal16.dll
geos_c.dll
iconv.dll
libcurl.dll
libexpat.dll
libfcgi.dll
libmap.dll
libpq.dll
libxml2.dll
mapserv.exe
pdflib.dll
proj.dll
spatialite.dll
web.config
xerces-c_2_8.dll
zlib1.dll
On Mon, Dec 7, 2009 at 9:46 AM, Daniel Walton <dgwalton at gmail.com> wrote:
> Thanks to all who've been helping me along. I'm getting close to having x64
> working now. I've worked through a slew of issues over the weekend, most
> related to permissions. My latest issue is that mapserv.exe, when invoked
> via IIS 7's FastCGI (classic mode) module, is returning blank images.
> GetCapabilities is working fine, and the GetMap images are the right size
> and format, but they're blank. Here's my setup: I downloaded and installed
> the x64 binaries (from Tamas, thanks!) into a single directory (C
> :\mapserver\). The IIS impersonated user has sufficient privileges on this
> folder and all data folders. I am accessing mapserver's WMS service with
> this URL:
> http://www.fireimagery.com/ms/mapserv.exe?map=C%3A%2Fmaps%2FA091207074551.map&SERVICE=WMS&REQUEST=GetMap&WIDTH=1680&HEIGHT=536&FORMAT=image/png&LAYERS=ZZ&S0TYLE=&BGCOLOR=0x888888&TRANSPARENT=FALSE&VERSION=1.3.0&CRS=EPSG:4326&BBOX=36.0156802563091,-123.307040153269,37.2036688809148,-119.583493717938&EXCEPTIONS=XML
> The corresponding mapfile text is as follows:
> MAP
>   EXTENT 36.0992948502284 -121.822480778145 36.3421121497716
> -121.520865221855
>   IMAGECOLOR 255 255 255
>   IMAGETYPE PNG
>   SIZE -1 -1
>   STATUS ON
>   UNITS DD
>   CONFIG PROJ_LIB "C:/mapserver/"
>   NAME "A091207074551"
>   OUTPUTFORMAT
>     NAME "aggpng24"
>     MIMETYPE "image/png"
>     DRIVER "AGG/PNG"
>     EXTENSION "PNG"
>     IMAGEMODE "RGBA"
>     TRANSPARENT TRUE
>   END
>   PROJECTION
>     "init=epsg:4326"
>   END
>   QUERYMAP
>     COLOR 255 255 0
>     SIZE -1 -1
>     STATUS OFF
>     STYLE HILITE
>   END
>   WEB
>     IMAGEPATH ""
>     IMAGEURL ""
>     METADATA
>       "wms_title"    "A091207074551"
>     END
>     QUERYFORMAT text/html
>     LEGENDFORMAT text/html
>     BROWSEFORMAT text/html
>   END
>   LAYER
>     DATA
> "C:\rawimages\A091207074551_output\A091207074551_0_config_PROCESS_RESULTS\BASINCOMPLEX_ftp.coloradoskye.com_2008_CA_Siege_080627_1200Local_SPOT_NIR_OUT.PNG"
> -121.520865221855
>     METADATA
>       "wms_srs"    "EPSG:4326"
>       "wms_extent"    "36.1 -121.8 36.3 -121.5"
>       "wms_title"
> "BASINCOMPLEX_FTP.COLORADOSKYE.COM_2008_CA_SIEGE_080627_1200LOCAL_SPOT_NIR"
>     END
>     NAME "ZZ"
>     PROJECTION
>       "init=epsg:4326"
>     END
>     STATUS ON
>     TYPE RASTER
>     UNITS DD
>   END
> END
> I have tried several different image formats and drivers, all produce blank
> images. Any ideas what might be wrong? Any way to set up more helpful error
> trapping?
> Thanks,
> Dan Walton
> GIS Fire Tools <http://gisfiretools.com>
> On Sun, Dec 6, 2009 at 4:04 PM, Tamas Szekeres <szekerest at gmail.com>wrote:
>> Daniel,
>> In bin/gdal/apps you can find the generic gdal/ogr applications, whereas
>> the applications in bin/gdal/csharp have been implemented by using the gdal
>> c# API. gdalinfo.exe and ogrinfo.exe provides similar functionalities in
>> both cases.
>> Best regards,
>> Tamas
>> 2009/12/6 Daniel Walton <dgwalton at gmail.com>
>> Tamas,
>>> In your binary distibutions there are 2 versions of gdalinfo.exe and
>>> ogrinfo.exe, one in bin/gdal/apps and the other in bin/gdal/csharp. What is
>>> the difference between the two versions?
>>> -Dan
>>> On Sat, Dec 5, 2009 at 3:31 AM, Tamas Szekeres <szekerest at gmail.com>wrote:
>>>> Have you configured mapping the .exe extension to this mapserv.exe with
>>>> your IIS application?
>>>> Make sure to enable CGI mode and copy all the x64 dll-s to the same
>>>> directory as the mapserv.exe application.
>>>> Set up the executing permissions to something like 'Scripts and
>>>> Executables'
>>>> Best regards,
>>>> Tamas
>>>> 2009/12/5 Daniel Walton <dgwalton at gmail.com>
>>>> Tamas,
>>>>> Update: I removed the CGI mapping and just used the default CGI hander
>>>>> in IIS. Now the request returns a file named mapserv.exe. I attached it as a
>>>>> text file. Again, thanks for any insights.
>>>>> -Dan
>>>>> On Fri, Dec 4, 2009 at 9:14 PM, Daniel Walton <dgwalton at gmail.com>wrote:
>>>>>> Tamas,
>>>>>> I installed the binaries from your website into c:\mapserver, added
>>>>>> all the paths to the system path variable, and set up the IIS folders. Now I
>>>>>> get a 500 internal error when trying to access mapserv.exe. The application
>>>>>> log gives this error:
>>>>>> *Faulting application mapserv.exe, version 0.0.0.0, time stamp
>>>>>> 0x4b1893cb, faulting module libmap.dll, version 6.0.6001.18000, time stamp
>>>>>> 0x4791adec, exception code 0xc0000135, fault offset 0x00000000000b1188,
>>>>>> process id 0x4bc, application start time 0x01ca7557ca56f442.*
>>>>>> Any idea what I'm doing wrong?
>>>>>> Thanks,
>>>>>> Dan
>>>>>> On Fri, Dec 4, 2009 at 2:22 PM, Tamas Szekeres <szekerest at gmail.com>wrote:
>>>>>>> I've mostly used this with IIS6,but it should however work on IIS7 as
>>>>>>> well.
>>>>>>> On IIS6 I configure a web server extensions to mapserv.exe (CGI mode)
>>>>>>> and fcgiext.dll (for FastCGI).
>>>>>>> Set up the executing permission (Scripts and Executables) and the
>>>>>>> application extension mapping (.exe) to mapserv.exe or fcgiext.dll.
>>>>>>> Best regards,
>>>>>>> Tamas
>>>>>>> 2009/12/4 Daniel Walton <dgwalton at gmail.com>
>>>>>>>> Tamas,
>>>>>>>> That's exactly what I was hoping you'd say! Which IIS module mapping
>>>>>>>> should I use for *.exe?
>>>>>>>> On Fri, Dec 4, 2009 at 1:55 PM, Tamas Szekeres <szekerest at gmail.com
>>>>>>>>>> Tamas,
>>>>>>>>>> Thanks for the reply. If I just want to use mapserver CGI as a WMS
>>>>>>>>>> server, do I need PHP? Is there another way to interact with mapserv.exe for
>>>>>>>>>> this limited purpose (e.g. an ASP.NET wrapper or something)?
>>>>>>>>>> -Dan
>>>>>>>>> Dan,
>>>>>>>>> If you use the MapServer CGI  (mapserv.exe) you wouldn't require to
>>>>>>>>> compile against PHP, the packages from
>>>>>>>>> http://vbkto.dyndns.org/sdk/ could be used without any change.
>>>>>>>>> Those packages also contain the MapScript C# interface
>>>>>>>>> (mapscript_csharp.dll) which would support creating ASP.NETapplications around the MapServer codebase when you have further
>>>>>>>>> requirements about the desired functionality.
>>>>>>>>> Best regards,
>>>>>>>>> Tamas
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091207/b404aa09/attachment.htm>
More information about the MapServer-users
