[mapserver-users] Mapserver WMS under IIS 7 x64 serving up blank
images
Daniel Walton
dgwalton at gmail.com
Mon Dec 7 16:18:09 EST 2009
I'm creating the PNG image from a GeoTIFF using:
gdal_translate -of PNG -quiet -scale -co worldfile=yes
[Geotiff_filename].tif [PNG_filename].PNG.
Also, these PNG source images were working fine under MS4W x86.
-Dan
On Mon, Dec 7, 2009 at 3:14 PM, Steve Lime <Steve.Lime at state.mn.us> wrote:
> If I take the request out of WMS context to straight CGI with this request:
> http://www.fireimagery.com/ms/mapserv.exe?map=C
> :\maps\A091207074551.map&mode=map&mapsize=300+300&layer=ZZ
> I get the following error:
> msDrawMap(): Image handling error. Failed to draw layer named 'ZZ'.
> msDrawRaster(): Image handling error. Unrecognized or unsupported image
> format drawEPP(): Image handling error. EPPL7 support is not available.
> Typically you'll see that when GDAL failed to identify the filetype. EPPL7
> is the last thing checked so that's not relevant by itself. I guess I'd
> start
> by making sure the image is valid.
> Steve
> >>> On 12/7/2009 at 2:47 PM, in message
> <8ab83e650912071247w7b93cb8bt90fe0c6a7a460785 at mail.gmail.com>, Daniel
> Walton
> <dgwalton at gmail.com> wrote:
> > Thanks Daniel. No dice, though, log is empty.
> > On Mon, Dec 7, 2009 at 2:38 PM, Daniel Morissette
> > <dmorissette at mapgears.com>wrote:
> >> Daniel Walton wrote:
> >>> Yes, the same mapfile worked under MS4W on a 32-bit machine. I have
> >>> verified that this same problem occurs using the x86 binaries from
> Tamas'
> >>> site run in the current x64 environment. The source image is in PNG
> format
> >>> in order to make transparency work well on the client. (My client is
> >>> Silverlight-based, and PNG is the only supported format that supports
> >>> transparency). The source image does have a world (*.WLD) file which
> >>> contains these values (file is generated by running gdal_translate on a
> >>> geotiff image):
> >> Um... perhaps try using DEBUG/MS_ERRORFILE and look for hints in the log
> >> output, if you haven't tried that already.
> >> Daniel Morissette
> >> http://www.mapgears.com/
> >> _______________________________________________
> >> mapserver-users mailing list
> >> mapserver-users at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091207/4c495a05/attachment.html
