[mapserver-users] Mapserver WMS under IIS 7 x64 serving up blank images
Daniel Walton dgwalton at gmail.com
Mon Dec 7 17:25:10 EST 2009
Tamas,
Thanks for the tip. I used process monitor and everything looks OK in the
permissions department. I think the problem relates to the fact that
mapserver doesn't calculate an overlap between map and layer. I'm not sure
what would cause this.
-Dan
On Mon, Dec 7, 2009 at 3:22 PM, Tamas Szekeres <szekerest at gmail.com> wrote:
> Daniel,
> This may also be an issue if GDAL couldn't actually open this file bacause
> of any reason (permission?).
> Make sure about this, by using a file monitoring tool, like SysInternals
> filemon for instance.
> Best regards,
> Tamas
> 2009/12/7 Steve Lime <Steve.Lime at state.mn.us>
> If I take the request out of WMS context to straight CGI with this request:
>>  http://www.fireimagery.com/ms/mapserv.exe?map=C
>> :\maps\A091207074551.map&mode=map&mapsize=300+300&layer=ZZ
>> I get the following error:
>> msDrawMap(): Image handling error. Failed to draw layer named 'ZZ'.
>> msDrawRaster(): Image handling error. Unrecognized or unsupported image
>> format drawEPP(): Image handling error. EPPL7 support is not available.
>> Typically you'll see that when GDAL failed to identify the filetype. EPPL7
>> is the last thing checked so that's not relevant by itself. I guess I'd
>> start
>> by making sure the image is valid.
>> Steve
>> >>> On 12/7/2009 at 2:47 PM, in message
>> <8ab83e650912071247w7b93cb8bt90fe0c6a7a460785 at mail.gmail.com>, Daniel
>> Walton
>> <dgwalton at gmail.com> wrote:
>> > Thanks Daniel. No dice, though, log is empty.
>> > On Mon, Dec 7, 2009 at 2:38 PM, Daniel Morissette
>> > <dmorissette at mapgears.com>wrote:
>> >> Daniel Walton wrote:
>> >>> Yes, the same mapfile worked under MS4W on a 32-bit machine. I have
>> >>> verified that this same problem occurs using the x86 binaries from
>> Tamas'
>> >>> site run in the current x64 environment. The source image is in PNG
>> format
>> >>> in order to make transparency work well on the client. (My client is
>> >>> Silverlight-based, and PNG is the only supported format that supports
>> >>> transparency). The source image does have a world (*.WLD) file which
>> >>> contains these values (file is generated by running gdal_translate on
>> a
>> >>> geotiff image):
>> >> Um... perhaps try using DEBUG/MS_ERRORFILE and look for hints in the
>> log
>> >> output, if you haven't tried that already.
>> >> Daniel Morissette
>> >> http://www.mapgears.com/
>> >> _______________________________________________
>> >> mapserver-users mailing list
>> >> mapserver-users at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091207/a544c439/attachment.html
