[mapserver-users] Shapefile, itemnquery and HTML image map generation problem
W.John Guineau guineau at earthlink.net
Mon Dec 7 20:49:37 EST 2009
I think the missing ones are from random places n the query string. I have
tried putting just one of the missing MLRA in the query string and it still
does not generate <area>
How do I label? (I am really new to MapServer!)
john
-----Original Message-----
From: Steve Lime [mailto:Steve.Lime at state.mn.us]
Sent: Monday, December 07, 2009 7:57 PM
To: W.John Guineau; mapserver-users at lists.osgeo.org; 'Steve Lime'
Subject: RE: [mapserver-users] Shapefile,itemnquery and HTML image map
generation problem
Do the ones not selected fall at the end of your qstring? I'm wondering if
something is getting truncated. I'd think
you'd get a parsing error in that case, but perhaps not. Can you label the
polygons with the value for MLRARSYM?
Steve
>>> On 12/7/2009 at 6:19 PM, in message
<01dc01ca779c$2c19eae0$844dc0a0$@net>,
W.John Guineau <guineau at earthlink.net> wrote:
> Hi Steve,
> OK, I added the QUERYMAP section and changed the URL:
> http://localhost/cgi-bin/mapserv?map=/NWPL_CRREL/MLRA/mlra.map
<http://localhost/cgi-bin/mapserv?map=/NWPL_CRREL/MLRA/mlra.map&qlayer=coe_m
&mode=itemnquerymap&searchmap=true&layer=states&mapext=-91+34+-89+49&mapsize
=600+400&qitem=MLRARSYM&qstring=(%22%5bMLRARSYM%5d%22%20in%20%22102A,102B,10
2C,103,104,105,106,107A,107B,108A,108B,108C,108D,109,110,111A,111B,111C,111D
> ,111E,112,113,114A,114B,115A,115B,115C%22)>
&qlayer=coe_m&mode=itemnquerymap&searchmap=true&layer=states&mapext=-91+34+-
89+49&mapsize=600+400&qitem=MLRARSYM&qstring=("[MLRARSYM]"%20in%20"102A,102B
,102C,103,104,105,106,107A,107B,108A,108B,108C,108D,109,110,111A,111B,111C,1
> 11D,111E,112,113,114A,114B,115A,115B,115C")
> Now I get the map with some of the items highlighted in yellow, and the
rest
> green:
> Sent: Monday, December 07, 2009 7:04 PM
> generation problem
> Just add a querymap object to your mapfile, like so:
> QUERYMAP
>   STATUS ON
> END
> Then change your URL to use the mode itemnquerymap and that should return
> just an image with the
> selected features highlighted in yellow.
> Steve
>>>> On 12/7/2009 at 5:56 PM, in message
> <01ce01ca7798$dd4b89d0$97e29d70$@net>,
>> I'm new to mapserver, how do I quickly generate a querymap?
>> I'm using mapserver 5.4.2 from the latest MS4W on Windows 7 x64. I've
also
>> tried 5.2.1 that I compiled myself.
>> john
>> Sent: Monday, December 07, 2009 6:40 PM
>> To: 'W.John Guineau'; mapserver-users at lists.osgeo.org
>> generation problem
>> GDAL's not in play here at all. If you generate a query map instead of an
>> html image map does
>> the output map look ok? What version are you using?
>> Steve
>>>>> On 12/4/2009 at 8:11 AM, in message
>> <04e001ca74eb$bc473400$34d59c00$@net>,
>>> How would I go about debugging this?
>>> I think this is GDAL and its query of shapefiles, right?
>>> The bottom line is that MapServer finds all the items when it is
> rendering
>>> the map by layer/class EXPRESSION, but the qstring in a URL using the
>> exact
>>> same EXPRESSION string misses some of the items.
>>> I can also use ogrinfo from MAP4W to execute an SQL query directly on
the
>>> shapefile and the items in questions are certainly there.
>>> In the image below, the green areas are result of the mapfile layer
class
>>> EXPRESSION - all are correctly rendered. However, several of them do not
>> get
>>> generated (HTML imagemap <area> tags not generated) when using a URL and
>>> itemnquery/qstring with the identical EXPRESSION.
>>> How do I enable debug (enabling mapfile DEBUG does not seem to give any
>>> useful info as to why GDAL is skipping certain items) Am I better off
>> using
>>> MAP4W or similar to get debug/trace info for shapefile queries?
>>> john
>>> From: mapserver-users-bounces at lists.osgeo.org
>>> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of W.John
>> Guineau
>>> Sent: Thursday, December 03, 2009 3:11 PM
>>> To: mapserver-users at lists.osgeo.org
>>> Subject: [mapserver-users] Shapefile, itemnquery and HTML image map
>>> generation problem
>>> I have a basic vector shapefile that I am trying to generate HTML
>> clickable
>>> maps from. It seems to work well for the most part, however there is a
>>> problem where some items from the shapefile do not get processed from
the
>>> qstring in the browser, but they are processed fine in the mapfile layer
>> (to
>>> color them differently).
>>> So the map that renders shows all the items colored properly as the
layer
>>> class defines. Using the exact same list of items in the HTTP query
> string
>>> causes several items to be ignored (the HTML image map area is not
>>> generated).
http://localhost/cgi-bin/mapserv?map=/NWPL_CRREL/MLRA/mlra.map&qlayer=coe_m&
mode=itemnquery&searchmap=true&layer=states&mapext=-91+34+-89+49&mapsize=600
+400&qitem=MLRARSYM&qstring=("[MLRARSYM]"%20in%20"102A,102B,102C,103,104,105
,106,107A,107B,108A,108B,108C,108D,109,110,111A,111B,111C,111D,111E,112,113,
>>> Below is the layer section from the mapfile. I can post whatever else is
>>> helpful.
>>> Thanks for any help on this.
>>> john
>>> LAYER
>>>                 NAME map_m
>>>                 DATA "map_shape"
>>>                 TEMPLATE "bodytemplate.html"
>>>                 HEADER "imapheader.html"
>>>                 FOOTER "imapfooter.html"
>>>                 PROJECTION
>>>                                 "proj=latlong"
>>>                                 "ellps=GRS80"
>>>                                 "init=epsg:4326"
>>>                 END
>>>                 TYPE polygon
>>>                 STATUS ON
>>>                 TRANSPARENCY 70
>>>                 CLASS
>>>                                 NAME "MLRA"
>>>                                 COLOR 0 200 0
>>>                                 OUTLINECOLOR 0 0 0
>>>                                 EXPRESSION( "[MLRARSYM]" in
"102A,102B,102C,103,104,105,106,107A,107B,108A,108B,108C,108D,109,110,111A,1
>>> 11B,111C,111D,111E,112,113,114A,114B,115A,115B,115C" )
>>>                 END
>>>                 METADATA
>>>                                 qstring_validation_pattern ".*"
>>>                 END
>>> END
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
