[mapserver-users] Layer based on a view renders faster than
if based on a table
Steve.Toutant at inspq.qc.ca
Tue Dec 8 09:59:07 EST 2009
Thanks Alan, I didn't know that.
Steve
Steve Toutant, M. Sc.
Analyste en géomatique
Secteur environnement
Direction de la santé environnementale et de la toxicologie
Institut national de santé publique du Québec
945, avenue Wolfe
Québec, Qc G1V 5B3
Tél.: (418) 650-5115 #5281
Fax.: (418) 654-3144
steve.toutant at inspq.qc.ca
http://www.inspq.qc.ca
Alan Boudreault <aboudreault at mapgears.com>@lists.osgeo.org
Envoyé par : mapserver-users-bounces at lists.osgeo.org
08/12/2009 09:39 AM
A
mapserver-users at lists.osgeo.org
cc
Steve.Toutant at inspq.qc.ca, Daniel Morissette <dmorissette at mapgears.com>,
Objet
Re: [mapserver-users] Layer based on a view renders faster than if
based on a table
Steve, Have you put the "DEBUG 5" directive at the layer level too ?
Alan
On December 8, 2009 09:36:27 am Steve.Toutant at inspq.qc.ca wrote:
> Daniel,
> I already set this in the mapfile
> DEBUG 5
> CONFIG MS_ERRORFILE "/ms4w/logs/mapserver.log"
> I don't get the SQL query in the log though.
> [Tue Dec 08 09:33:56 2009].961000 msDrawMap(): Layer 17 (RSSincidCumul),
> 0.390s
> [Tue Dec 08 09:33:56 2009].992000 msDrawMap(): Drawing Label Cache,
0.031s
> [Tue Dec 08 09:33:56 2009].992000 msDrawMap() total time: 0.421s
> [Tue Dec 08 09:33:57 2009].8000 msSaveImage() total time: 0.016s
> [Tue Dec 08 09:33:57 2009].24000 mapserv request processing time
> (msLoadMap not incl.): 0.453s
> [Tue Dec 08 09:33:57 2009].24000 msFreeMap(): freeing map at 01516C50.
> 945, avenue Wolfe
> Québec, Qc G1V 5B3
> Daniel Morissette <dmorissette at mapgears.com>@lists.osgeo.org
> 04/12/2009 05:05 PM
> A
> cc
> Objet
> Re: [mapserver-users] Layer based on a view renders faster than if based
> on a table
> > I thought that a layer definition based on a table would be much
faster
> > than on a view.
> > What should be the expected behavior please?
> > Please tell me is this should be asked to postgis forum.
> I'd suggest you capture the exact SQL query that is run in each case
> (using DEBUG/MS_ERRORFILE) and check that the difference in time indeed
> comes form the PostGIS queries.
> If that's the case then you could submit a question to the postgis list
> based on that, taking MapServer out of the equation.
> If on the other hand the queries take about the same time and the time
> difference is in MapServer's code (which I doubt) then we'd need more
> details (ideally a testcase) to be able to reproduce and troubleshoot
> the issue.
> Daniel
Alan Boudreault
Mapgears
http://www.mapgears.com
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091208/1cbb2dbb/attachment.html
