[mapserver-users] Item Query
Jay Kapalczynski
jkapalczynski at ci.maple-grove.mn.us
Tue Dec 8 16:35:31 EST 2009
Wondering if this is possible?
I have a Service set up to allow the user to input a few choices.
I then am attempting to send those to a .map file to query a layer
Can this be done...I am grabbing at straws here because I don't even know if this can be done?
Service from an xml file:
<service title="SearchByPID" selectable="false" default="false" locked="true" div="PIDsearch">
<url>/cgi-bin/mapserv.exe</url>
<input type="hidden" name="map" value="/ms4w/apps/GeoMOOSE/Maple_Grove_GeoMoose/itemquery_PID.map"/>
<input type="hidden" name="mode" value="nquery"/>
<input type="hidden" name="layer" value="parcels"/>
<input type="select" name="PropertyType" title="Property Type:">
<option value="Commercial">Commercial</option>
<option value="Residential">Residential</option>
<option value="Single Family">Single Family</option>
<option value="Townhome">Townhome</option>
<option value="Twinhome/Zero Lot">Twinhome/Zero Lot</option>
</input>
<input type="select" name="PriceFactor" title="Price Factor:">
<option value="Greater Than">Greater Than</option>
<option value="Less Than">Less Than</option>
<option value="Between">Between</option>
<option value="Equal To">Equal To</option>
<option value="Greater Than Equal To">Greater Than Equal To</option>
<option value="Less Than Equal To">Less Than Equal To</option>
</input>
</service>
.map file being called from above.... IS there a way to Use the filter to query the shapefile with the values from the two comboboxes above?
Can I make a where clause in the Filter....
Filter * WHERE Propertytype (above combobox) and PriceFactor (above combobox)
LAYER # Parcels Polygon Layer
NAME 'Parcels'
DATA 'parcels/parcels.shp'
STATUS DEFAULT
TYPE POLYGON
METADATA
qstring_validation_pattern '.'
END
TEMPLATE 'parcels/identpar.html'
FILTERITEM 'PID'
FILTER /^%idPID%/
END
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091208/99b4b4e1/attachment-0001.html
