[mapserver-users] GetLegendGraphic, class name, no label
Yewondwossen Assefa
yassefa at dmsolutions.ca
Tue Dec 8 20:53:32 EST 2009
Hi Steve,
Have you tried to add width and height parameters in your request with
the rule specified: ...&width=20&height=20&Format=gif&RULE=my_rule
That should allow you to get the exact size. If not I believe the
default sizes are taken from the keysize parameter legend block in the
map file. If not defined it will default to 20/10.
regards,
Steve.Toutant at inspq.qc.ca wrote:
> Hi,
> I'm using GetLegendGraphic to get an icon.
> I don't want any label so I don't give a class name in the layer
> definition.
> I have a layer with several classes. I would like to get the icon for
> the last class only, without the label.
> I tried to use RULE=className in the request, and give a className to
> my last class, but the icon is distorted, too big.
> If I keep only one class (the last one I want) in the mapfile, without
> a classname, and without RULE key in the request the icon I get is good.
> Is there some more information I need to use RULE key in the request?
> Maybe I misunderstood this key uses.
> thanks
> steve
> mapserver-users at lists.osgeo.org
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
