[mapserver-users] How do I use ASRP maps in mapserver?
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed Dec 9 10:58:49 EST 2009
Jeff McKenna wrote:
> Alans wrote:
>> Can anyone tell me how to use ASRP maps in mapserver, or point me at some
>> relevant documentation. The GDAL list of supported raster formats
>> indicates
>> that this should be possible
>> (http://www.gdal.org/frmt_various.html#SRP) but
>> I can't find any instructions as to how to specify this format in a
>> LAYER of
>> a .map file.
> Hello Alans,
> Interesting. I have never used that format but I can give some hints.
> First, you should execute 'gdalinfo --formats' on your server to check
> if you has SRP support. Look for something like "SRP (ro) : Standard
> Raster Product (ASRP/USRP)" in the returned list of formats; this will
> verify that your local MapServer/GDAL build can read the ASRP format.
> Next, you can point to the image in your mapfile layer, such as (and I'm
> guessing this, as I don't have your data to test):
> LAYER
> NAME "ASRP"
> DATA "myfile.img"
> TYPE RASTER
> STATUS ON
> END
> (a good document for you to read about raster support in MapServer is
> http://www.mapserver.org/input/raster.html)
> Finally, you could test your mapfile with the shp2img commandline
> utility, to see any error reports
> (http://www.mapserver.org/utilities/shp2img.html)
> I hope this helps you a little.
> -jeff
Sorry Alans,
I forgot an import step:
After verifying SRP support with 'gdalinfo --formats', next step is to
see if GDAL can read your exact file, by using gdalinfo again:
gdalinfo myfile.img
You should see some info returned such as Size, Pixel Size,
Coordinates...etc.
Then you can focus on your mapfile layer.
-jeff
Jeff McKenna
FOSS4G Consulting and Training Services
http://www.gatewaygeomatics.com/
