AW: [mapserver-users] How do I Control QUERY Output?
Bill Thoen bthoen at gisnet.com
Wed Dec 9 16:59:22 EST 2009
Thanks again, Arnd.
That solution occurred to me this morning, so I'm going to try that out
next. The other acceptable solution would be to open a new pop-up window
and send the output there, but I think the AJAX method will be the
better one for what I want it to do.
Arnd Wippermann wrote:
> Hi,
> You cann't insert html to a html document by using a url. There is nothing
> like the img tag for pictures.
> You have to use ajax to request your query. Then you can put the result with
> innerHTML to your element.
> Arnd
> -----Ursprüngliche Nachricht-----
> Von: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Im Auftrag von Bill Thoen
> Gesendet: Mittwoch, 9. Dezember 2009 00:53
> An: mapserver-users at lists.osgeo.org
> Betreff: [mapserver-users] How do I Control QUERY Output?
>  From a simple MapServer HTML interface I switch to Query mode and click on
> a map feature, and templates I've assigned to the layer fill with data ...
> and display in a new page. What I'd like is for the info to display in a
> floating div and not disrupt the view by clearing the map just to display a
> small window of data. I'd also prefer to not use frames as well.
> With JavaScript I can make a floating drag-able div box, but I can't figure
> out how to get the template to send its table of data to the div.
> I've tried removing the HTML header and just appending the table to the div
> using innerHTML, but I keep getting null elements or other errors.
> Is this approach right and I'm just missing something, or is this done
> another way? I spent the better part of an hour today searching for docs
> and/or examples, but either it wasn't to be found or my google-fu was
> inferior today. Can someone point me to an example or explain how you can
> put query output anywhere on the map page?
> Bill Thoen
> GISnet -  www.gisnet.com
> 1401 Walnut St., Suite C
> Boulder, CO 80302
> 303-786-9961 tel
> 303-443-4856 fax
