[mapserver-users] make error - version 5.6.0-rc1 - /usr/bin/ld:
cannot find -lxslt
Alan Boudreault
aboudreault at mapgears.com
Fri Dec 11 13:05:38 EST 2009
The file name is not important. Theorically, ldconfig should read all those
files and add it to its lib path. Unfortunately, I don't know much Fedora but
it should work that way.
Alan
On December 11, 2009 12:55:24 pm Ted Spradley wrote:
> Thanks Alan, and others. I realize my server admin skills are lacking.
> So, file.conf should be named 'lpam.conf' or 'libpam.conf'? (tried both,
> then ldconfig as root ... still the same error)
> Ted S.
> ----- Original Message -----
> From: Alan Boudreault [via OSGeo.org]
> To: Ted Spradley
> Sent: Friday, December 11, 2009 10:27 AM
> Subject: Re: [mapserver-users] make error - version 5.6.0-rc1 -
> /usr/bin/ld: cannot find -lxslt
> You could simply add the path to ldconfig. Add a file.conf in
> /etc/ld.so.conf.d/ which contains only a line with: /lib/
> and type "ldconfig" as root.
> Alan
> On December 11, 2009 11:08:59 am Ted Spradley wrote:
> > Stephen Woodbridge wrote:
> > > http://www.google.com/#hl=en&source=hp&q=fedora+7+libpam
> > > -Steve
> > Not having libpam doesn't appear to be the issue. It just can't find
> > it.
> > /usr/bin/ld: cannot find -lpam
> > # locate libpam
> > /lib/libpam.so.0
> > /lib/libpam.so.0.81.6
> > /lib/libpam_misc.so.0
> > /lib/libpam_misc.so.0.81.2
> > /lib/libpamc.so.0
> > /lib/libpamc.so.0.81.0
> > /root/psa/PSA_8.4.0/dist-rpm-FedoraCore-7-i386/base/psa-libpam-plesk-8.
> >4.0- fc7.build84080425.19.i586.rpm
> > /root/psa/PSA_9.2.3/dist-rpm-FedoraCore-7-i386/base/psa-libpam-plesk-9.
> >2.3 -fc7.build92091015.22.i586.rpm
> > /swsoft/PSA_8.3.0/dist-rpm-FedoraCore-7-i386/base/psa-libpam-plesk-8.3.
> >0-f c7.build83071218.19.i586.rpm
> > Is there any way to feed make the path for this library?
> > Thanks, Ted S.
> View message @
> http://n2.nabble.com/make-error-version-5-6-0-rc1-usr-bin-ld-cannot-find-l
> xslt-tp4148052p4152220.html To unsubscribe from Re: make error - version
> 5.6.0-rc1 - /usr/bin/ld: cannot find -lxslt, click here.
Alan Boudreault
Mapgears
http://www.mapgears.com
