[mapserver-users] Expression Syntax
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Fri Dec 11 13:55:45 EST 2009
No, you'd take their input and convert it before submitting. So if they type
'hello' you'd convert it to '[Hh][Ee][Ll][Ll][Oo]' before sending. You could
do something like that in javascript I suppose.
If you split them apart the filter would get applied first (so you'd see candidate
Features with the right block value only) and then the expression would be used. My
suggestion/workaround was pretty specific to your message and might not make sense
depending on how the whole layer looks. For example, if you've got multiple classes
then that approach won't work.
Steve
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Jay Kapalczynski
Sent: Friday, December 11, 2009 12:08 PM
To: Lime, Steve D (DNR)
Cc: mapserver-users at lists.osgeo.org
Subject: RE: [mapserver-users] Expression Syntax
My example I am having the user fill the query...so I don't know what they are entering....
Are you hinting at doing that with the whole alphabet?
/idOwnerQueryDESC/ => [Aa][Bb][Cc][Dd] etc etc
If I split them apart like you suggested how does the "AND" statement of the logical expression get referenced?
Thanks Steve for your thoughts and comments...apprecaited...
Thanks
From: Lime, Steve D (DNR) [mailto:Steve.Lime at state.mn.us]
Sent: Friday, December 11, 2009 9:29 AM
To: Jay Kapalczynski
The =~ is the regex operator. It's referenced in a "Note" just below all the other logical expressions... Probably
should just be inlined with the other examples.
You can write case insensitive regex's the brute force way, e.g.:
/hello/ => /[Hh][Ee][Ll][Ll][Oo]/
Bit of a pain though. Also, if you could isolate the regex somehow and remove your block test then you could do a
straight regex expression and use case insensitivity. For example,
FILTERITEM 'block'
FILTER '%idOwnerQueryBLOCK%'
CLASSITEM 'USE1_DESC'
CLASS
EXPRESSION /.*%idOwnerQueryDESC%.*/i
END
Might even see better performance...
Steve
________________________________________
From: Jay Kapalczynski [jkapalczynski at ci.maple-grove.mn.us]
Sent: Friday, December 11, 2009 9:17 AM
Thanks Steve for you response
I have been scouring the documentation on expressions and was getting confused..
This is from Mapserver
( ( ... ) AND ( ... ) ) ( ( ... ) && ( ... ) ) ... will become true when both of the two logical expressions in the innermost brackets are true.
Although my solution followed (...AND...) NOT ((...) AND (...))
I didn't see the ~ in the documentation...what is that doing is signifying?
I had to remove the i so I am not longer case insensitive.....thats a drag...guess I have to modify my attributes to LCase to get around that...
Any other thoughts about the case sensitive issue...any way around that with the Logical Expression...
Thanks again everyone for you help and suggestions.
Sent: Friday, December 11, 2009 8:55 AM
Try:
FILTER ('[USE1_DESC]' =~ /.*%idOwnerQueryDESC%.*/i AND '[BLOCK]'='%idOwnerQueryBLOCK%')
I've not tried case insensitive regex in a logical expression though. You might have to remove the i...
Steve
From: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org] On Behalf Of Jay Kapalczynski [jkapalczynski at ci.maple-grove.mn.us]
Sent: Friday, December 11, 2009 8:37 AM
To: Fawcett, David (MPCA); 'Emiliano Castañeda'
Thanks for all your help yesterday..very appreciated.seems I always get botched up with the syntax..
Ugggg.I have tried 20 different ways and I just seem to be missing something..
I guess the question is, Can I use a wild card search in a logical expression?
This works (WILD CARD )
FILTER /.*%idOwnerQueryDESC%.*/i
This works (NO WILD CARD)
FILTER ('[USE1_DESC]'='%idOwnerQueryDESC%' AND '[BLOCK]'='%idOwnerQueryBLOCK%')
This DOSENT work (Cant get the wild card into this)
FILTER ('[USE1_DESC]'=' /.*%idOwnerQueryDESC%.*/i' AND '[BLOCK]'='%idOwnerQueryBLOCK%')
Any thoughts?
Thanks
Sent: Thursday, December 10, 2009 3:57 PM
To: 'Fawcett, David (MPCA)'; 'Emiliano Castañeda'
Thanks all for your thoughts..
Got it.I had to add ' ' around the textbox id as well when referencing the textbox id names
Notice( '%idOwnerQueryDESC%' and '%idOwnerQueryBLOCK%' )
Dan thanks for your thoughts.I am going to be moving to 2.x soon..but have to have the time to lean this all over again.moving to open layers that is..
One step at a time.I have a ton programmed into 1.6 that's going to take me some time to convert.
Thanks again all..very appreciated
From: Fawcett, David (MPCA) [mailto:David.Fawcett at state.mn.us]
Sent: Thursday, December 10, 2009 3:26 PM
To: Jay Kapalczynski; 'Emiliano Castañeda'
At a minimum, I think that you will need to add quotes around the query columns. (just use single quotes, not the fancy Microsofty ones below.)
FILTER ('[USE1_DESC]'=%idOwnerQueryDESC% AND '[BLOCK]'=%idOwnerQueryBLOCK%)
Try setting a filter with static values from your data to get the filter format working before you add the complexity of passing the values in with variables.
FILTER ('[USE1_DESC]'='myUse' AND '[BLOCK]'='myBlock')
David.
Sent: Thursday, December 10, 2009 3:21 PM
To: 'Emiliano Castañeda'
Emiliano thanks for the response..yea I looked at the documentation and it was a bit fuzzy to me.
If I do them individually it works:
#FILTERITEM 'USE1_DESC'
#FILTER /.*%idOwnerQueryDESC%.*/i
#FILTERITEM 'BLOCK'
#FILTER /.*%idOwnerQueryBLOCK%.*/i
FILTER ([USE1_DESC]=%idOwnerQueryDESC% AND [BLOCK]=%idOwnerQueryBLOCK%)
ERROR: msEvalExpression: Expression parser error. Failed to parse expression: =Residential AND =006
FILTER (USE1_DESC=%idOwnerQueryDESC% AND BLOCK=%idOwnerQueryBLOCK%)
I seemed to get a bunch of returns that were incorrect...seems like it grabbed all of them.
Thoughts?
From: Emiliano Castañeda [mailto:emilianocastaneda at suremptec.com.ar]
Sent: Thursday, December 10, 2009 2:13 PM
Subject: Re: [mapserver-users] Expression Syntax
Jay,
you must use FILTERITEM only for simple FILTER expressions (string comparison only)
for example:
FILTER "2005" ->fieldvalue
FILTERITEM "year" ->fieldname
For Logical FILTER expressions you do not define FILTERITEM. In this case you must place the FILTER between parentheses, and fieldnames between brackets
for example:
FILTER ([field1]<4000 AND "[field2]"=="Museum") -->observe quotes on both sides on text fields
See http://mapserver.org/mapfile/expressions.html#expressions for detail on how to build logical expressions
Regards,
Emiliano
2009/12/10 Jay Kapalczynski <jkapalczynski at ci.maple-grove.mn.us<mailto:jkapalczynski at ci.maple-grove.mn.us>>
I looked on map server website in the documentation and cant get the synstax correct
I have two textboxes idOwner and idOwner2
I am a bit confused on the FILTERITEM because I am trying to write the expression to include two fields.
USE1_DESC and BLOCK are the two fields that form the query
LAYER # Parcels Owner Layer
NAME 'Parcels'
DATA 'parcels/parcels.shp'
STATUS DEFAULT
TYPE POLYGON
METADATA
qstring_validation_pattern '.'
END
TEMPLATE 'parcels/itemquery_parcels_Owner.html'
FILTER (* WHERE USE1_DESC = '%idOwner%' and BLOCK = '%idOwner2%')
END
mapserver-users mailing list
mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapserver-users
Ing. Emiliano Castañeda
SUR Emprendimientos Tecnológicos
Ing. Huergo 1189 (C1007AOL)
Ciudad de Buenos Aires, Argentina
Tel. +54 (11) 5811-4552 ext. 107
emilianocastaneda at suremptec.com.ar<mailto:emilianocastaneda at suremptec.com.ar>
www.suremptec.com<http://www.suremptec.com>
