[mapserver-users] WFS namespace URI problem
Balázs Bámer
bamerbalazs at gmail.com
Sun Dec 13 14:07:27 EST 2009
Hi All,
I try to serve WFS from Oracle Spatial data source under Mapserver
5.4.2 WMS runs fine, WFS compilation requirements are fulfilled:
./configure --with-oci
--with-oraclespatial=/usr/local/instantclient_11_1 --with-proj
--with-threads --with-gdal --with-ogr --with-jpeg --with-png=/usr/lib
--with-php=/usr/include/php5 --with-wmsclient --with-wfsclient
--with-fastcgi=/usr --with-wfs
The following GetFeature request complains about namespace URI problems:
http://att-it.homelinux.net:22080/cgi-bin/ms-5.4.2/blokknez.fcgi?service=wfs&version=1.0.0&request=getfeature&maxfeatures=1&typename=blokknezegeto:blokk2009
or
http://att-it.homelinux.net:22080/cgi-bin/ms-5.4.2/blokknez.fcgi?service=wfs&version=1.0.0&request=getfeature&maxfeatures=1&typename=blokk2009
What is the problem?
Thank you in advance, best regards: Balázs Bámer
Here is the interesting part (three other layers cut) of my mapfile:
MAP
NAME BLOKKNEZ
STATUS ON
SIZE 650 500
# xmin ymin xmax ymax?
EXTENT 420000 40000 950000 370000
UNITS METERS
PROJECTION
"init=epsg:23700"
END
SHAPEPATH "."
IMAGECOLOR 200 200 200
IMAGETYPE JPEG
FONTSET fonts.txt
DEBUG 5
#CONFIG "MS_ERRORFILE" "/var/log/mapserver-5.4.2/error.txt"
CONFIG "ON_MISSING_DATA" "LOG"
WEB
MINSCALEDENOM 10000
MAXSCALEDENOM 1000000
IMAGEPATH "/tmp"
IMAGEURL "/tmp"
LOG "/var/log/mapserver-5.4.2/ms_error.txt"
METADATA
"wms_title" "Blokkhatar nezegeto"
"wfs_title" "Blokkhatar nezegeto"
"wms_onlineresource"
"http://att-it.homelinux.net:22080/cgi-bin/ms-5.4.2/blokknez.fcgi?"
"wfs_onlineresource"
"wms_srs" "EPSG:23700"
"wfs_srs" "EPSG:23700"
END
END
OUTPUTFORMAT
NAME png32
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE RGBA
EXTENSION "png"
END
LAYER
PROCESSING "CLOSE_CONNECTION=DEFER"
NAME blokk2009
METADATA
"DESCRIPTION" "blokk2009"
"wms_title" "blokk2009"
"wfs_title" "blokk2009"
"wfs_include_items" "all"
"gml_include_items" "all"
"gml_featureid" "tfotvbaz"
"wfs_extent" '426400 43800 937400 362900'
"wfs_featureid" "tfotvbaz"
"wfs_maxfeatures" '1000'
"wfs_encoding" 'UTF-8'
"wfs_namespace_prefix" 'blokknezegeto'
"wfs_namespace_uri" 'http://att-it.homelinux.net/blokknezegeto/blokk2009'
END
PROJECTION
"init=epsg:23700"
END
TYPE POLYGON
MINSCALEDENOM 999
MAXSCALEDENOM 200001
STATUS ON
CONNECTIONTYPE oraclespatial
CONNECTION "blokkhatar/bh2357WETU@(DESCRIPTION=(ADDRESS_LIST=(ADDRESS=(PROTOCOL=TCP)(HOST=10.0.8.52)(PORT=1521)))(CONNECT_DATA=(SID=oragis)))"
DATA "bgeom from (SELECT bgeom,bloaz,bpter/10000.0 as
bpterha,tfotvbaz FROM tfotvb where tolda =
to_Date('20090303','YYYYMMDD')) using unique tfotvbaz SRID 23700"
CLASS
NAME "blokk2009"
STYLE
OUTLINECOLOR 55 55 255
END
END
DUMP TRUE
TEMPLATE "template.html"
DEBUG 5
END # layer blokk2009
END # Map File
