[mapserver-users] make error - version 5.6.0-rc1 - /usr/bin/ld: cannot find -lxslt
Daniel Morissette dmorissette at mapgears.com
Tue Dec 15 13:50:23 EST 2009
The linker looks for .so files, the *.so.x and *.so.x.y are used only at
runtime, so you need libpam.so, which is usually provided by the -devel
version of the RPM package.
Daniel
Ted Spradley wrote:
> Stephen Woodbridge wrote:
>> http://www.google.com/#hl=en&source=hp&q=fedora+7+libpam
>> -Steve
> Not having libpam doesn't appear to be the issue.  It just can't find it.
> /usr/bin/ld: cannot find -lpam
> # locate libpam
> /lib/libpam.so.0
> /lib/libpam.so.0.81.6
> /lib/libpam_misc.so.0
> /lib/libpam_misc.so.0.81.2
> /lib/libpamc.so.0
> /lib/libpamc.so.0.81.0
> /root/psa/PSA_8.4.0/dist-rpm-FedoraCore-7-i386/base/psa-libpam-plesk-8.4.0-fc7.build84080425.19.i586.rpm
> /root/psa/PSA_9.2.3/dist-rpm-FedoraCore-7-i386/base/psa-libpam-plesk-9.2.3-fc7.build92091015.22.i586.rpm
> /swsoft/PSA_8.3.0/dist-rpm-FedoraCore-7-i386/base/psa-libpam-plesk-8.3.0-fc7.build83071218.19.i586.rpm
> Is there any way to feed make the path for this library?
> Thanks, Ted S.
Daniel Morissette
http://www.mapgears.com/
