[mapserver-users] many warnings when using make to build mapserver
rory greene
rorygreene1 at gmail.com
Fri Dec 18 07:53:34 EST 2009
Hi
I've built mapscript on ubuntu linux using source software for gd, gdal,
curl geos php postgis postgresql proj and mapserver.
I am worried about the final step in the process as during the make step I
seen many warnings being generated flying by. I include most of the output
below. Is there a file generated of all the 'make' output that I can use to
show you if needed?
The mapserv executable was made and after adding /usr/local/pgsql/lib to the
ld.so.conf and flushing with /sbin/ldconfig (because of a failure to find
libpq) the test for functional mapserver worked ie I got the following a
request for mapserv:
This script can only be used to decode form results and
should be initiated as a CGI process via a httpd server.
Is the presence of the warnings a normal feature or should i continue to
worry?
Thanks anyone who looks at this.
*Here is my configure options* (I saved these in a text for such an
occasion) No output errors seemed to appear for the configure step
./configure --with-ogr=/usr/local/bin/gdal-config
--with-gdal=/usr/local/bin/gdal-config
--with-httpd=/usr/local/apache2/bin/httpd --with-wfsclient --with-wmsclient
--enable-debug --with-curl-config=/usr/local/bin/curl-config
--with-proj=/usr/local --with-tiff --with-gd=/usr/local --with-jpeg
--with-freetype=/usr --with-threads --with-wcs
--with-postgis=/usr/local/pgsql/bin/pg_config
--with-geos=/usr/local/bin/geos-config
--with-xml2-config=/usr/bin/xml2-config --with-sos
--with-php=/home/rory/php/php-5.2.3 --with-wfs --with-png
*Here is part of the make output*
F -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DGD_HAS_FTEX_XSHOW
-DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS -DUSE_ICONV -DUSE_ZLIB
-I/usr/local/include -I/usr/local/include -I/usr/local/include
-I/usr/local/pgsql/include -I/usr/local/include -I/usr/local/include
-I/usr/include/libxml2 mapprimitive.c -o mapprimitive.o
mapprimitive.c:35: warning: ‘cvsid_aw’ defined but not used
gcc -c -g -O2 -fPIC -Wall -DNEED_NONBLOCKING_STDERR -DHAVE_VSNPRINTF
-DNEED_STRLCAT -DNEED_STRRSTR -DNEED_NONBLOCKING_STDERR -DUSE_WMS_LYR
-DUSE_WFS_LYR -DUSE_SOS_SVR -DUSE_LIBXML2 -DUSE_CURL -DUSE_WCS_SVR
-DUSE_WFS_SVR -DUSE_WMS_SVR -DUSE_POSTGIS -DUSE_TIFF -DUSE_GDAL -DUSE_OGR
-DUSE_GEOS -DUSE_THREAD -DUSE_PROJ -DUSE_EPPL -DUSE_GD_GIF -DUSE_GD_PNG
-I/usr/include/libxml2 mapproject.c -o mapproject.o
mapproject.c:35: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 mapraster.c -o mapraster.o
mapraster.c: In function ‘readGEOTiff’:
mapraster.c:453: warning: pointer targets in passing argument 1 of
‘TIFFSwabShort’ differ in signedness
mapraster.c:452: warning: ignoring return value of ‘fread’, declared with
attribute warn_unused_result
mapraster.c:456: warning: ignoring return value of ‘fread’, declared with
mapraster.c:472: warning: ignoring return value of ‘fread’, declared with
mapraster.c:475: warning: ignoring return value of ‘fread’, declared with
mapraster.c: In function ‘msDrawRasterLayerLow’:
mapraster.c:1491: warning: ignoring return value of ‘fread’, declared with
mapraster.c: At top level:
mapraster.c:39: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 mapsde.c -o mapsde.o
g++ -c -g -O2 -fPIC -Wall -DNEED_NONBLOCKING_STDERR -DHAVE_VSNPRINTF
-I/usr/include/libxml2 mapogr.cpp -o mapogr.o
-I/usr/include/libxml2 mappostgis.c -o mappostgis.o
mappostgis.c:71: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 mapmygis.c -o mapmygis.o
mapmygis.c:39: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 maplayer.c -o maplayer.o
maplayer.c:35: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 mapresample.c -o mapresample.o
mapresample.c:34: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 mapwms.c -o mapwms.o
mapwms.c:49: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 mapwmslayer.c -o mapwmslayer.o
-I/usr/include/libxml2 maporaclespatial.c -o maporaclespatial.o
maporaclespatial.c:42: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 mapgml.c -o mapgml.o
mapgml.c:34: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 mapprojhack.c -o mapprojhack.o
-I/usr/include/libxml2 mapthread.c -o mapthread.o
mapthread.c:140: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 mapdraw.c -o mapdraw.o
mapdraw.c:35: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 mapgd.c -o mapgd.o
mapgd.c: In function ‘msImageLoadGD’:
mapgd.c:435: warning: ignoring return value of ‘fread’, declared with
mapgd.c: At top level:
mapgd.c:43: warning: ‘cvsid_aw’ defined but not used
mapgd.c:1031: warning: ‘drawVectorSymbolGD’ defined but not used
-I/usr/include/libxml2 -Wno-uninitialized mapagg.cpp -o mapagg.o
-I/usr/include/libxml2 mapoutput.c -o mapoutput.o
mapoutput.c:33: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 mapgdal.c -o mapgdal.o
mapgdal.c:34: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 mapswf.c -o mapswf.o
-I/usr/include/libxml2 mapimagemap.c -o mapimagemap.o
mapimagemap.c:41: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 mapows.c -o mapows.o
mapows.c: In function ‘msOWSGetProjURN’:
mapows.c:1659: warning: format not a string literal and no format arguments
mapows.c: At top level:
mapows.c:37: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 mapwfs.c -o mapwfs.o
mapwfs.c:31: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 mapwfs11.c -o mapwfs11.o
mapwfs11.c:33: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 mapwfslayer.c -o mapwfslayer.o
mapwfslayer.c:40: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 mapcontext.c -o mapcontext.o
mapcontext.c:31: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 maphttp.c -o maphttp.o
maphttp.c:40: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 mapdrawgdal.c -o mapdrawgdal.o
mapdrawgdal.c:36: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 mappdf.c -o mappdf.o
-I/usr/include/libxml2 mapjoin.c -o mapjoin.o
mapjoin.c:32: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 mapgraticule.c -o mapgraticule.o
mapgraticule.c:33: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 mapcopy.c -o mapcopy.o
mapcopy.c:48: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 mapogcfilter.c -o mapogcfilter.o
mapogcfilter.c:38: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 mapogcsld.c -o mapogcsld.o
mapogcsld.c: In function ‘msSLDApplySLDURL’:
mapogcsld.c:98: warning: ignoring return value of ‘fread’, declared with
mapogcsld.c: In function ‘msSLDGetGraphicSymbol’:
mapogcsld.c:2036: warning: ignoring return value of ‘fread’, declared with
mapogcsld.c: In function ‘msSLDParseExpression’:
mapogcsld.c:5441: warning: format not a string literal and no format
arguments
mapogcsld.c:5442: warning: format not a string literal and no format
arguments
mapogcsld.c:5476: warning: format not a string literal and no format
arguments
mapogcsld.c: At top level:
mapogcsld.c:37: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 maptime.c -o maptime.o
maptime.c:39: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 mapwcs.c -o mapwcs.o
mapwcs.c:35: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 mapwcs11.c -o mapwcs11.o
mapwcs11.c:38: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 mapcpl.c -o mapcpl.o
mapcpl.c:44: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 cgiutil.c -o cgiutil.o
cgiutil.c:39: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 maprasterquery.c -o maprasterquery.o
maprasterquery.c:35: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 mapobject.c -o mapobject.o
mapobject.c:38: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 mapgeos.c -o mapgeos.o
-I/usr/include/libxml2 classobject.c -o classobject.o
classobject.c:39: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 layerobject.c -o layerobject.o
layerobject.c:39: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 mapio.c -o mapio.o
mapio.c:40: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 mappool.c -o mappool.o
mappool.c:133: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 mapsvg.c -o mapsvg.o
mapsvg.c:40: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 mapregex.c -o mapregex.o
-I/usr/include/libxml2 mappluginlayer.c -o mappluginlayer.o
mappluginlayer.c:33: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 mapogcsos.c -o mapogcsos.o
mapogcsos.c:33: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 mappostgresql.c -o mappostgresql.o
mappostgresql.c:53: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 mapcrypto.c -o mapcrypto.o
mapcrypto.c:37: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 mapowscommon.c -o mapowscommon.o
mapowscommon.c:45: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 maplibxml2.c -o maplibxml2.o
maplibxml2.c:39: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 mapdebug.c -o mapdebug.o
mapdebug.c:56: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 mapchart.c -o mapchart.o
mapchart.c:33: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 maptclutf.c -o maptclutf.o
maptclutf.c:92: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 epplib.c -o epplib.o
epplib.c: In function ‘clrreset’:
epplib.c:392: warning: ignoring return value of ‘fgets’, declared with
epplib.c: At top level:
epplib.c:37: warning: ‘cvsid_aw’ defined but not used
ar rc libmapserver.a mapgeomtransform.o maprgbapng.o maptemplate.o mapbits.o
maphash.o mapshape.o mapxbase.o mapparser.o maplexer.o maptree.o mapsearch.o
mapstring.o mapsymbol.o mapfile.o maplegend.o maputil.o mapscale.o
mapquery.o maplabel.o maperror.o mapprimitive.o mapproject.o mapraster.o
mapsde.o mapogr.o mappostgis.o mapmygis.o maplayer.o mapresample.o mapwms.o
mapwmslayer.o maporaclespatial.o mapgml.o mapprojhack.o mapthread.o
mapdraw.o mapgd.o mapagg.o mapoutput.o mapgdal.o mapswf.o mapimagemap.o
mapows.o mapwfs.o mapwfs11.o mapwfslayer.o mapcontext.o maphttp.o
mapdrawgdal.o mappdf.o mapjoin.o mapgraticule.o mapcopy.o mapogcfilter.o
mapogcsld.o maptime.o mapwcs.o mapwcs11.o mapcpl.o cgiutil.o
maprasterquery.o mapobject.o mapgeos.o classobject.o layerobject.o mapio.o
mappool.o mapsvg.o mapregex.o mappluginlayer.o mapogcsos.o mappostgresql.o
mapcrypto.o mapowscommon.o maplibxml2.o mapdebug.o mapchart.o maptclutf.o
epplib.o
ranlib libmapserver.a
# We don't want to let the shared library get out of sync with the
# static library if it exists.
if test -r libmapserver.so ; then \
make shared ; \
fi
-I/usr/include/libxml2 shp2img.c -o shp2img.o
shp2img.c:33: warning: ‘cvsid_aw’ defined but not used
g++ -g -O2 -fPIC -Wall -DNEED_NONBLOCKING_STDERR -DHAVE_VSNPRINTF
-I/usr/include/libxml2 shp2img.o -L. -lmapserver -L/usr/local/lib -lgd
-ljpeg -lfreetype -lz -lpng -lz -ltiff -ljpeg -lfreetype -lz -lpng -lz
-L/usr/local/lib -lproj -ljpeg -lpng -L/usr/local/lib -lgdal
-L/usr/local/lib -lgeos_c -ljpeg -ltiff -lpng -lz -lm -lrt -ldl
-L/usr/local/pgsql/lib -lpq -L/usr/local/lib -lcurl -L/usr/local/lib
-lgeos_c -lpthread -lc -lz -lxml2 -lm -lstdc++ -o shp2img
-I/usr/include/libxml2 shp2pdf.c -o shp2pdf.o
shp2pdf.c:32: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 shp2pdf.o -L. -lmapserver -L/usr/local/lib -lgd
-lgeos_c -lpthread -lc -lz -lxml2 -lm -lstdc++ -o shp2pdf
-I/usr/include/libxml2 legend.c -o legend.o
legend.c:32: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 legend.o -L. -lmapserver -L/usr/local/lib -lgd
-lgeos_c -lpthread -lc -lz -lxml2 -lm -lstdc++ -o legend
-I/usr/include/libxml2 mapserv.c -o mapserv.o
mapserv.c:42: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 maptile.c -o maptile.o
-I/usr/include/libxml2 mapserv.o cgiutil.o maptile.o -L. -lmapserver
-L/usr/local/lib -lgd -ljpeg -lfreetype -lz -lpng -lz -ltiff -ljpeg
-lfreetype -lz -lpng -lz -L/usr/local/lib -lproj -ljpeg -lpng
-L/usr/local/lib -lgdal -L/usr/local/lib -lgeos_c -ljpeg -ltiff -lpng -lz
-lm -lrt -ldl -L/usr/local/pgsql/lib -lpq -L/usr/local/lib -lcurl
-L/usr/local/lib -lgeos_c -lpthread -lc -lz -lxml2 -lm -lstdc++ -o
mapserv
-I/usr/include/libxml2 shptree.c -o shptree.o
shptree.c:34: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 shptree.o -L. -lmapserver -L/usr/local/lib -lgd
-lgeos_c -lpthread -lc -lz -lxml2 -lm -lstdc++ -o shptree
-I/usr/include/libxml2 shptreevis.c -o shptreevis.o
shptreevis.c:38: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 shptreevis.o -L. -lmapserver -L/usr/local/lib -lgd
-lgeos_c -lpthread -lc -lz -lxml2 -lm -lstdc++ -o shptreevis
-I/usr/include/libxml2 shptreetst.c -o shptreetst.o
shptreetst.c:35: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 shptreetst.o -L. -lmapserver -L/usr/local/lib -lgd
-lgeos_c -lpthread -lc -lz -lxml2 -lm -lstdc++ -o shptreetst
-I/usr/include/libxml2 scalebar.c -o scalebar.o
scalebar.c:32: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 scalebar.o -L. -lmapserver -L/usr/local/lib -lgd
-lgeos_c -lpthread -lc -lz -lxml2 -lm -lstdc++ -o scalebar
-I/usr/include/libxml2 sortshp.c -o sortshp.o
sortshp.c:39: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 sortshp.o -L. -lmapserver -L/usr/local/lib -lgd
-lgeos_c -lpthread -lc -lz -lxml2 -lm -lstdc++ -o sortshp
touch mapscriptvars
pwd > mapscriptvars
echo -DHAVE_VSNPRINTF -DNEED_STRLCAT -DNEED_STRRSTR
-DNEED_NONBLOCKING_STDERR -DUSE_WMS_LYR -DUSE_WFS_LYR -DUSE_SOS_SVR
-DUSE_LIBXML2 -DUSE_CURL -DUSE_WCS_SVR -DUSE_WFS_SVR -DUSE_WMS_SVR
-DUSE_POSTGIS -DUSE_TIFF -DUSE_GDAL -DUSE_OGR -DUSE_GEOS -DUSE_THREAD
-DUSE_PROJ -DUSE_EPPL -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG
-DUSE_GD_WBMP -DUSE_GD_FT -DGD_HAS_FTEX_XSHOW -DGD_HAS_GDIMAGEGIFPTR
-DGD_HAS_GETBITMAPFONTS -DUSE_ICONV -DUSE_ZLIB >> mapscriptvars
echo -I. -I/usr/local/include -I/usr/local/include -I/usr/local/include
-I/usr/local/include >> mapscriptvars
echo -L. -lmapserver -L/usr/local/lib -lgd -ljpeg -lfreetype -lz -lpng
-lz -ltiff -ljpeg -lfreetype -lz -lpng -lz -L/usr/local/lib -lproj
-ljpeg -lpng -L/usr/local/lib -lgdal -L/usr/local/lib -lgeos_c -ljpeg
-ltiff -lpng -lz -lm -lrt -ldl -L/usr/local/pgsql/lib -lpq
-L/usr/local/lib -lcurl -L/usr/local/lib -lgeos_c -lpthread -lc -lz
-lxml2 -lm -lstdc++ >> mapscriptvars
echo >> mapscriptvars
grep '#define MS_VERSION ' mapserver.h >> mapscriptvars
-I/usr/include/libxml2 tile4ms.c -o tile4ms.o
tile4ms.c:46: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 tile4ms.o -L. -lmapserver -L/usr/local/lib -lgd
-lgeos_c -lpthread -lc -lz -lxml2 -lm -lstdc++ -o tile4ms
-I/usr/include/libxml2 msencrypt.c -o msencrypt.o
msencrypt.c:32: warning: ‘cvsid_aw’ defined but not used
-I/usr/include/libxml2 msencrypt.o -L. -lmapserver -L/usr/local/lib -lgd
-lgeos_c -lpthread -lc -lz -lxml2 -lm -lstdc++ -o msencrypt
rm -f mapserver-config
echo '#!/bin/sh' > mapserver-config
echo 'CONFIG_LIBS="-L/usr/local/lib -lgd -ljpeg -lfreetype -lz -lpng -lz
-ltiff -ljpeg -lfreetype -lz -lpng -lz -L/usr/local/lib -lproj -ljpeg
-lpng -L/usr/local/lib -lgdal -L/usr/local/lib -lgeos_c -ljpeg -ltiff -lpng
-lz -lm -lrt -ldl -L/usr/local/pgsql/lib -lpq -L/usr/local/lib -lcurl
-L/usr/local/lib -lgeos_c -lpthread -lc -lz -lxml2 -lm -lstdc++ "' >>
mapserver-config
echo 'CONFIG_DEP_LIBS=""' >> mapserver-config
echo 'CONFIG_CFLAGS="-g -O2 -fPIC -Wall -DNEED_NONBLOCKING_STDERR
-DGD_HAS_GETBITMAPFONTS -DUSE_ICONV -DUSE_ZLIB -I/usr/local/include
-I/usr/local/include -I/usr/local/include -I/usr/local/pgsql/include
-I/usr/local/include -I/usr/local/include -I/usr/include/libxml2 "' >>
mapserver-config
echo 'CONFIG_DEFINES=" -DHAVE_VSNPRINTF -DNEED_STRLCAT -DNEED_STRRSTR
-DGD_HAS_GETBITMAPFONTS -DUSE_ICONV -DUSE_ZLIB "' >> mapserver-config
echo 'CONFIG_INCLUDES=" -I/usr/local/include -I/usr/local/include
-I/usr/local/include -I/usr/local/pgsql/include -I/usr/local/include
-I/usr/local/include -I/usr/include/libxml2 "' >> mapserver-config
echo 'CONFIG_VERSION="'`grep '#define MS_VERSION ' mapserver.h | sed
's/\"//g' | sed 's/#define MS_VERSION //'`'"' >> mapserver-config
cat mapserver-config.in >> mapserver-config
chmod a+x mapserver-config
cd mapscript/php3; make; cd ../..
make[1]: Entering directory
`/home/rory/mapserver542/mapserver-5.4.2/mapscript/php3'
gcc -fPIC -g -O2 -fPIC -Wall -DUSE_PHP_REGEX -DCOMPILE_DL=1 -DPHP4
-I/home/rory/mapserver542/mapserver-5.4.2 -I/usr/include/libxml2
-I/home/rory/php/php-5.2.3 -I/home/rory/php/php-5.2.3/dl
-I/home/rory/php/php-5.2.3/main -I/home/rory/php/php-5.2.3/Zend
-I/home/rory/php/php-5.2.3/include -I/home/rory/php/php-5.2.3/TSRM
-I/home/rory/php/php-5.2.3/ -c -o php_mapscript_util.o php_mapscript_util.c
-I/home/rory/php/php-5.2.3/ -c -o php_mapscript.o php_mapscript.c
-I/home/rory/php/php-5.2.3/ -c -o mapscript_i.o mapscript_i.c
-I/home/rory/php/php-5.2.3/ -c -o php_regex.o php_regex.c
g++ -shared -o php_mapscript.so php_mapscript_util.o php_mapscript.o
mapscript_i.o php_regex.o -L/home/rory/mapserver542/mapserver-5.4.2
-lmapserver -lxml2 -L/usr/local/lib -lcurl -L/usr/local/pgsql/lib -lpq
-ltiff -ljpeg -lfreetype -lz -lpng -lz -L/usr/local/lib -lgdal
-L/usr/local/lib -lgeos_c -lpthread -L/usr/local/lib -lproj
-L/usr/local/lib -lgd -ljpeg -lfreetype -lz -lpng -lz -lc -lz -lm
-lstdc++
make[1]: Leaving directory
root at rory-desktop:/home/rory/mapserver542/mapserver-5.4.2#
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091218/744e085b/attachment-0001.html
