[mapserver-users] mapserver 5.6.0, RFC 52 and driver support
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Tue Dec 22 16:52:25 EST 2009
The new-style approach opens the template only once. That's not your bottleneck though I bet...
-----Original Message-----
From: Brent Fraser [mailto:bfraser at geoanalytic.com]
Sent: Tuesday, December 22, 2009 3:34 PM
To: Lime, Steve D (DNR)
Cc: mapserver-users at lists.osgeo.org
Subject: RE: [mapserver-users] mapserver 5.6.0, RFC 52 and driver support
> What kind of templating are you using? The old-style stuff or the
> new-style? How many results you talking?
Old style. Low 100's of records returned...
> Sent: Tuesday, December 22, 2009 3:10 PM
> The strange thing is the image render is quick (a few seconds), but the
> nquery+mapshape (rectangle) with the processing of the template is several
> minutes. And while it opens/reads/closes the template file for each
> record(!), I suspect the majority of the time is spent requesting the
> record and dealing with the result.
> Ok, on goes the hacker suit...
> Thanks!
> Brent
>> Probably a question better answered by OGR maintainers... In theory
>> working off a single
>> result set, even if you have to traverse it more than once, would be far
>> more efficient
>> than id-based lookups done now.
>> Steve
>> From: mapserver-users-bounces at lists.osgeo.org
>> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Brent
>> Fraser
>> Sent: Tuesday, December 22, 2009 2:55 PM
>> support
>> Do you think there would be any point in making the changes for OGR (for
>> my ODBC -> Sql Server connection)? If so, I'll start having a look at
>> the
>> code...
>> Brent
>>> The improvements are limited to native drivers only, principally Oracle
>>> Spatial and PostGIS.
>>> Steve
>>> Fraser
>>> Sent: Tuesday, December 22, 2009 2:48 PM
>>> To: mapserver-users at lists.osgeo.org
>>> Subject: [mapserver-users] mapserver 5.6.0, RFC 52 and driver support
>>> To all,
>>> I've got a query performance problem I'm trying to track down. I was
>>> hopeful that 5.6 with RFC 52 implemented might help me, but it seems to
>>> have no impact.
>>> Are the changes for RFC 52 implemented for OGR ODBC connections?
>>> Thanks!
>>> Brent Fraser
>>> mapserver-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
