[mapserver-users] mapserver 5.6.0, RFC 52 and driver support
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Tue Dec 22 17:17:52 EST 2009
Yup. What sort of an example would help?
-----Original Message-----
From: Brent Fraser [mailto:bfraser at geoanalytic.com]
Sent: Tuesday, December 22, 2009 4:18 PM
To: Lime, Steve D (DNR)
Cc: mapserver-users at lists.osgeo.org
Subject: RE: [mapserver-users] mapserver 5.6.0, RFC 52 and driver support
I'd like to give the new-style approach a try, but the doc seems a little
thin. You've talking about RFC 36 right?
> The new-style approach opens the template only once. That's not your
> bottleneck though I bet...
> Sent: Tuesday, December 22, 2009 3:34 PM
>> What kind of templating are you using? The old-style stuff or the
>> new-style? How many results you talking?
> Old style. Low 100's of records returned...
>> Sent: Tuesday, December 22, 2009 3:10 PM
>> support
>> The strange thing is the image render is quick (a few seconds), but the
>> nquery+mapshape (rectangle) with the processing of the template is
>> several
>> minutes. And while it opens/reads/closes the template file for each
>> record(!), I suspect the majority of the time is spent requesting the
>> record and dealing with the result.
>> Ok, on goes the hacker suit...
>> Thanks!
>> Brent
>>> Probably a question better answered by OGR maintainers... In theory
>>> working off a single
>>> result set, even if you have to traverse it more than once, would be
>>> far
>>> more efficient
>>> than id-based lookups done now.
>>> Steve
>>> From: mapserver-users-bounces at lists.osgeo.org
>>> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Brent
>>> Fraser
>>> Sent: Tuesday, December 22, 2009 2:55 PM
>>> support
>>> Do you think there would be any point in making the changes for OGR
>>> (for
>>> my ODBC -> Sql Server connection)? If so, I'll start having a look at
>>> the
>>> code...
>>> Brent
>>>> The improvements are limited to native drivers only, principally
>>>> Oracle
>>>> Spatial and PostGIS.
>>>> Steve
>>>> Fraser
>>>> Sent: Tuesday, December 22, 2009 2:48 PM
>>>> To: mapserver-users at lists.osgeo.org
>>>> Subject: [mapserver-users] mapserver 5.6.0, RFC 52 and driver support
>>>> To all,
>>>> I've got a query performance problem I'm trying to track down. I
>>>> was
>>>> hopeful that 5.6 with RFC 52 implemented might help me, but it seems
>>>> to
>>>> have no impact.
>>>> Are the changes for RFC 52 implemented for OGR ODBC connections?
>>>> Thanks!
>>>> Brent Fraser
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
