[mapserver-users] mapserver 5.6.0, RFC 52 and driver support
Brent Fraser bfraser at geoanalytic.com
Tue Dec 22 17:54:48 EST 2009
For those following this thread, I used:
   OUTPUTFORMAT
     NAME 'UnassignedWells_select_template'
     DRIVER 'TEMPLATE'
     MIMETYPE 'text/html'
     FORMATOPTION 'FILE=database\UnassignedWells_select_template_test.html'
   END
and added
[resultset layer="UnAssignedWells"][feature]
[/feature][/resultset]
around the per-record text in UnassignedWells_select_template_test.html
But as suspected, it still didn't solve my performance problem...
Brent
> I've got:
>   OUTPUTFORMAT
>     DRIVER 'TEMPLATE'
>     TEMPLATE 'database\UnassignedWells_select_template_test.html'
> #?    FORMATOPTION
>   END
> in my map file and a command line of:
> mapserv
> QUERY_STRING="mode=nquery&qformat=UnassignedWells_select_template&map=select2_Test.map&qlayer=UnAssignedWells&"
> Am I close?
> Thanks
> Brent
>> Yup. What sort of an example would help?
>> -----Original Message-----
>> From: Brent Fraser [mailto:bfraser at geoanalytic.com]
>> Sent: Tuesday, December 22, 2009 4:18 PM
>> To: Lime, Steve D (DNR)
>> Cc: mapserver-users at lists.osgeo.org
>> Subject: RE: [mapserver-users] mapserver 5.6.0, RFC 52 and driver
>> support
>> I'd like to give the new-style approach a try, but the doc seems a
>> little
>> thin.  You've talking about RFC 36 right?
>>> The new-style approach opens the template only once. That's not your
>>> bottleneck though I bet...
>>> Sent: Tuesday, December 22, 2009 3:34 PM
>>> support
>>>> What kind of templating are you using? The old-style stuff or the
>>>> new-style? How many results you talking?
>>> Old style.  Low 100's of records returned...
>>>> Sent: Tuesday, December 22, 2009 3:10 PM
>>>> support
>>>> The strange thing is the image render is quick (a few seconds), but
>>>> the
>>>> nquery+mapshape (rectangle) with the processing of the template is
>>>> several
>>>> minutes.  And while it opens/reads/closes the template file for each
>>>> record(!), I suspect the majority of the time is spent requesting the
>>>> record and dealing with the result.
>>>> Ok, on goes the hacker suit...
>>>> Thanks!
>>>> Brent
>>>>> Probably a question better answered by OGR maintainers... In theory
>>>>> working off a single
>>>>> result set, even if you have to traverse it more than once, would be
>>>>> far
>>>>> more efficient
>>>>> than id-based lookups done now.
>>>>> Steve
>>>>> From: mapserver-users-bounces at lists.osgeo.org
>>>>> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Brent
>>>>> Fraser
>>>>> Sent: Tuesday, December 22, 2009 2:55 PM
>>>>> support
>>>>> Do you think there would be any point in making the changes for OGR
>>>>> (for
>>>>> my ODBC -> Sql Server connection)?  If so, I'll start having a look
>>>>> at
>>>>> the
>>>>> code...
>>>>> Brent
>>>>>> The improvements are limited to native drivers only, principally
>>>>>> Oracle
>>>>>> Spatial and PostGIS.
>>>>>> Steve
>>>>>> Fraser
>>>>>> Sent: Tuesday, December 22, 2009 2:48 PM
>>>>>> To: mapserver-users at lists.osgeo.org
>>>>>> Subject: [mapserver-users] mapserver 5.6.0, RFC 52 and driver
>>>>>> support
>>>>>> To all,
>>>>>>   I've got a query performance problem I'm trying to track down.  I
>>>>>> was
>>>>>> hopeful that 5.6 with RFC 52 implemented might help me, but it seems
>>>>>> to
>>>>>> have no impact.
>>>>>>   Are the changes for RFC 52 implemented for OGR ODBC connections?
>>>>>> Thanks!
>>>>>> Brent Fraser
>>>>>> _______________________________________________
>>>>>> mapserver-users mailing list
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
