[mapserver-users] msGetEncodedString(): General error message.
Not implemeted since Iconv is not enabled.
Daniel Morissette
dmorissette at mapgears.com
Thu Dec 24 12:55:18 EST 2009
I'd suggest you try adding --with-libiconv=/usr/local to your configure
options to force configure to enable it, and then 'make clean;make'
Daniel
woodhead31 wrote:
> Hi,
> I am moving from windows to freebsd 7.2, but got some error:
> msGetEncodedString(): General error message. Not implemeted since Iconv is
> not enabled.
> OS: freebsd 7.2
> Mapserver: installed from ports
> The map file works perfect in a windows system, and I just move the whole
> application to freebsd, including mapfile , symbols, fonts etc. I think
> it's the iconv problem.
>>From the install manual:
> http://mapserver.org/installation/unix.html#libgd
> I belive it's the GD and ICONV problem, so try to execute
> gdlib-config --libs
> and got:
> -lXpm -lX11 -ljpeg -lfontconfig -lfreetype -lz -lm
> /usr/local/lib/libiconv.so -Wl,-rpath -Wl,/usr/local/lib
> I have iconv installed:
> pkg_info |grep iconv
> libiconv-1.13.1 A character set conversion library
> I think I installed iconv(as the pkg_info shows), and make gd with iconv(as
> the gdlib-config shows).
> what should I do then?
> thanks!
Daniel Morissette
http://www.mapgears.com/
