[mapserver-users] How to render raster data using Oracle Georaster?
xxj
2001xxj at gmail.com
Thu Dec 31 05:38:32 EST 2009
Hi folks,
Is Oracle Georaster supported by MapServer?
I am using MapServer5.6.0 and can render vector data using Oracle
successfully. But when I was trying raster data using Oracle database, the
following errors happens.
Errors:
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<!DOCTYPE ServiceExceptionReport SYSTEM
"http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.1">
<ServiceException>
msDrawMap(): Image handling error. Failed to draw layer named
'bluemarble'.
msDrawRaster(): Unable to access file.
georaster:wz/wz at orclat18,sf_rasters,georaster,georid=101 using full path
</ServiceException>
</ServiceExceptionReport>
My layer definition in mapfile is as following:
LAYER
NAME bluemarble
TYPE raster
STATUS ON
#CONNECTIONTYPE oraclespatial
#CONNECTION "wz/wz at orclat18"
#DATA "geor:wz/wz at orclat18,student_rdt_01,id=1"
DATA "georaster:wz/wz at orclat18,sf_rasters,georaster,georid=101"
#DATA drgncimq1926.tif
#DATA "georaster from sf_rasters using srid 8307"
#DATA "GEOR:temporary.vrt"
CLASS
EXPRESSION ([pixel] >= 0 AND [pixel] <= 1000)
STYLE
COLOR 255 0 0
END
END
METADATA
WMS_TITLE "bluemarble"
WMS_ABSTRACT "bluemarble."
WMS_SRS "EPSG:4326"
END
END
I am very sure that GDAL and GeoRaster are compiled into MapServer and well
configured for the belows are the output about them.
Output of mapserv:
[oracle at ts cgi-bin]$ ./mapserv -v
./mapserv: /usr/lib/libxml2.so.2: no version information available (required
by ./mapserv)
MapServer version 5.6.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=WBMP OUTPUT=SVG
SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WCS_SERVER INPUT=EPPL7 INPUT=ORACLESPATIAL INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
Output of gdal_translate:
[oracle at ts cgi-bin]$ gdal_translate |grep Geo
GTiff: GeoTIFF
GeoRaster: Oracle Spatial GeoRaster
I have ever tried to confirm that if gdal is OK by executing the command of
"gdal_translate -of gtiff
geor:wz/wz at orclat18,sf_rasters,georaster,georid=101 bluemarble.tiff -outsize
100% 100%"
in the command line. And found it's OK, the expected picture file was
returned.
I am so confused by the errors above now! So I wonder how to render raster
data with Oracle and GDAL on MapServer?
Thanks!
View this message in context: http://n2.nabble.com/How-to-render-raster-data-using-Oracle-Georaster-tp4235902p4235902.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
