[mapserver-users] application\vnd.ogc.se_inimage format
Yewondwossen Assefa yassefa at dmsolutions.ca
Mon Feb 2 09:47:34 EST 2009
Hi There,
  Is the IMAGETYPE parameter set in your map file? If not you might want
to try it  by adding something like  this in your map file:
  IMAGETYPE png (or any other valid formats that you want).
Best Regards
Piebe de Vries wrote:
> hi,
> I configured a layer to return png only. When my application  does a
> getMap request (using format=image/png) a png picture is returned.
> Everything fine so far. However if an error occurs the same request
> (using exceptions=application\vnd.ogc.se_inimage) returns a gif picture.
> And my application is not very happy with that...(also the wms standards
> specifies that the image returned should be the one asked in the format
> parameter)
> I am using mapserver 5.2.1 Can anybody confirm this behavior?
> Thanks,
> Piebe
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
