[mapserver-users] Different SIZEUNITS for line width and label fontsize
Vladimir Cvejanovic vladimir at gessolutions.com
Tue Feb 3 06:41:50 EST 2009
Hi Thomas,
Thanks for your reply. I have already plaid around with MINSIZE and
MAXSIZE. They are a good way to avoid the labels being displayed when
they are too small to read. Also coupled with MINSCALE and MAXSCALE
class definitions I was able to set up three classes for large, medium
and small text depending on the scale used.
This isn't a bad solution at all but I wanted to see if there is away to
prevent the labels scaling at all within the same layer definition as
the scalable (real-world sized) lines.
Thanks,
Vladimir
thomas bonfort wrote:
> hi,
> you can use minsize and maxsize in your label: these are always pixels:
> size 8
> minszie 8
> maxsize 8
> regards,
> thomas
> On Tue, Feb 3, 2009 at 12:17, Vladimir Cvejanovic
> <vladimir at gessolutions.com> wrote:
>> Hi All,
>> In the Mapfile, Is it possible to have different SIZEUNTIS for line width
>> and label font in the same layer? The example is below.
>> I have managed to solve this by defining two layers one which only displays
>> the line and one which only displays the labels however this seems like a
>> hack and very inefficient from a processing / querying point of view.
>> The context is a line layer containing road lines which have a width in
>> meters but labels in pixels. This would make things scale nicely Can this be
>> done? Does anyone have a better approach?
>> Thanks,
>> Vladimir
>> LAYER
>>   NAME 'highway'
>>   TYPE LINE
>>   DATA 'highway.shp'
>>   STATUS DEFAULT
>>   TRANSPARENCY 30
>>   LABELITEM "NAME"
>>   SIZEUNITS meters
>>   CLASS
>>      NAME 'highway'
>>      STYLE
>>        WIDTH 5 #WANT THESE TO BE METERS
>>        COLOR 55 55 55
>>      END
>>      LABEL
>>       TYPE TRUETYPE
>>       FONT FreeSans
>>       SIZE 08 # WANT THESE TO BE PIXELS
>>       COLOR 0 0 0
>>       OUTLINECOLOR 255 255 255
>>       ANTIALIAS TRUE
>>       ANGLE AUTO
>>       MINFEATURESIZE AUTO
>>       FORCE true
>>     END
>>   END
>>  END
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
