[mapserver-users] application\vnd.ogc.se_inimage format
Yewondwossen Assefa
yassefa at dmsolutions.ca
Tue Feb 3 10:07:20 EST 2009
I could reproduce a GIF output for the exception image in some
particular cases. I have added a bug on it
http://trac.osgeo.org/mapserver/ticket/2874 and committed a patch.
Please give it a try and update the bug.
Best Regards,
Piebe de Vries wrote:
> imagetype is set to png
> the only defined output type is png
> Yewondwossen Assefa wrote:
>> Hi There,
>> Is the IMAGETYPE parameter set in your map file? If not you might
>> want to try it by adding something like this in your map file:
>> IMAGETYPE png (or any other valid formats that you want).
>> Best Regards
>>> hi,
>>> I configured a layer to return png only. When my application does a
>>> getMap request (using format=image/png) a png picture is returned.
>>> Everything fine so far. However if an error occurs the same request
>>> (using exceptions=application\vnd.ogc.se_inimage) returns a gif
>>> picture. And my application is not very happy with that...(also the
>>> wms standards specifies that the image returned should be the one
>>> asked in the format parameter)
>>> I am using mapserver 5.2.1 Can anybody confirm this behavior?
>>> Thanks,
>>> Piebe
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
