[mapserver-users] Using IMAGECOLOR to create a transparency mask
gwaldron gwaldron at gmail.com
Wed Feb 4 14:58:16 EST 2009
Roger, Andre,
Thanks for your suggestions .... unfortunately none of these ideas worked
for me. I will keep banging away at it and let me know if I discover
anything.
Glenn
Roger André wrote:
> Hey guys,
> Have a try resetting your OUTPUTFORMAT to this:
>   OUTPUTFORMAT
>     NAME 'AGGA'
>     DRIVER AGG/PNG
>     MIMETYPE "image/png"
>     IMAGEMODE RGBA
>     EXTENSION "png"
>     FORMATOPTION "INTERLACE=OFF"
>   END
> Transparency works for me with this.
> On Wed, Feb 4, 2009 at 11:05 AM, Mike Dunham-Wilkie
> <mike at barrodale.com>wrote:
>> Sorry Glenn, I don't have an answer, but I've been dealing with the same
>> problem.
>> Transparency seems to work as expected with:
>> OUTPUTFORMAT
>>   NAME png24
>>   DRIVER "GD/PNG"
>>   IMAGEMODE RGBA
>>   EXTENSION "png"
>>   TRANSPARENT ON
>> END
>> but not with:
>> OUTPUTFORMAT
>>   NAME 'AGG'
>>   DRIVER AGG/PNG
>>   IMAGEMODE RGBA
>>   FORMATOPTION "PALETTE_FORCE=TRUE"
>>   FORMATOPTION "PALETTE="
>>   TRANSPARENT ON
>> END
>> It's as if with AGG/PNG the TRANSPARENT ON setting is completely ignored.
>> Mike
>> At 10:52 AM 04/02/2009, gwaldron wrote:
>> I'm trying to use IMAGECOLOR to try to force all pixels of a certain
>> color
>> to
>> become fully transparent, but I am not having any luck getting it to
>> work.
>> My output format it AGG/PNG, RGBA, TRANSPARENT ON.
>> I have a shapefile layer set to COLOR 0 50 100, and my map-level
>> IMAGECOLOR
>> set to the same. I was hoping all the polys in the shapefile would render
>> as
>> transparent pixels, but no luck; they just show up as blue polygons.
>> What am I doing wrong here? Thanks.
>> Glenn Waldron * Pelican Mapping * gwaldron at pelicanmapping.com * +1 703
>> 652
>> 4791
>> View this message in context:
>> http://n2.nabble.com/Using-IMAGECOLOR-to-create-a-transparency-mask-tp2270688p2270688.html
>> Sent from the Mapserver - User mailing list archive at Nabble.com.
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>>  http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> Michael Dunham-Wilkie, M.Sc., M.P.A.
>> Senior Database Analyst
>> Barrodale Computing Services Ltd.
>> Tel: (250) 472-4372 Fax: (250) 472-4373
>> Web:  http://www.barrodale.com
>> Email: mike at barrodale.com
>> Mailing Address:
>> P.O. Box 3075 STN CSC
>> Victoria BC Canada V8W 3W2
>> Shipping Address:
>> Hut R, McKenzie Avenue
>> University of Victoria
Glenn Waldron * Pelican Mapping * gwaldron at pelicanmapping.com * +1 703 652
4791
View this message in context: http://n2.nabble.com/Using-IMAGECOLOR-to-create-a-transparency-mask-tp2270688p2271134.html
