[mapserver-users] How to change a layer's DATA attribute via URL?
Steve Lime
Steve.Lime at dnr.state.mn.us
Thu Feb 5 09:56:41 EST 2009
You have to set a DATAPATTERN in the webObj (I think) so that someone just can't
change that value to anything. For example you might consider:
DATAPATTERN "^IMG_[0-9]{5}\.tif$"
The value for DATAPATTERN is a regex.
Steve
>>> Dirk Jesko <ml.dje at geocontent.de> 02/05/09 8:48 AM >>>
Hello,
I would like to change the DATA attribute of a layer via URL. Mapserver
is called using the cgi interface. The layer definition is
LAYER
NAME "luftbild"
DATA "IMG_01646.tif"
TYPE RASTER
TRANSFORM UL
PROCESSING "RESAMPLE=BILINEAR"
END
Now I would like to select the image that shall be displayed using the
URL, e.g.
... &MAPEXT=0 500 500 1000&mapsize=256
256&map.layer[luftbild]=DATA+"IMG_01648.tif"
However, this just results in the following error message:
loadLayer(): General error message. URL-based DATA configuration failed
pattern validation.
Any idea?
Thanks for any help,
Dirk
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
