[mapserver-users] Multilingual map files
Peter Hopfgartner
peter.hopfgartner at r3-gis.com
Fri Feb 6 05:28:46 EST 2009
Kralidis,Tom [Ontario] wrote:
>> -----Original Message-----
>> From: mapserver-users-bounces at lists.osgeo.org
>> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of
>> Peter Hopfgartner
>> Sent: Wednesday, 04 February 2009 08:47
>> To: mapserver-users at lists.osgeo.org
>> Cc: Paolo Viskanic
>> Subject: [mapserver-users] Multilingual map files
>> Dear list members
>> I would like ask how map files for multilingual applications
>> are handled by mapserver users.
>> Multilingual information may impact the map in various ways.
>> As by now, those come to mind:
>> * Fix strings in the map file, (NAME, DESCRIPTION etc)
>> * Database borne data, changing column for different
>> languages as for LABELITEM
>> * Queries changing with language, so that DATA/FILTER
>> statements must be adapted to the current language (e.g.
>> WHERE lang_id='en').
>> What we are currently doing is to write the mapfiles like:
>> CLASS
>> NAME "IT:Progetti linee|DE:Projekte Linien"
>> SYMBOL 'circle'
>> SIZE 3
>> COLOR 0 0 255
>> END
>> METADATA
>> "DESCRIPTION" "IT:Progetti|DE:Projekte"
>> END
>> LABELITEM "IT:gemi|DE:gemd"
>> and modify the labels through Mapscript before rendering the
>> map. This works if the map file is processed by Mapscript,
>> whereas it would not work for CGI and W*S services. We would
>> need a map file for each language for those services.
> For WxS, the specs themselves don't handle this, but it would be nice to
> handle multilingual metadata in one document, i.e.:
> <Name xml:lang="en-CA">road</Name>
> <Name xml:lang="fr-CA">rue</Name>
I remember Arnulf Christel mentioning some work on multilingual WxS by
OGC. Do you know anything about this?
> In our environment, we've created one mapfile / language. One thing you
> could do is use MapScript WxS to intercept an incoming request (say with
> an extended lang parameter), then, once you have the lang, set the
> values in the mapfile accordingly.
> ..Tom
Thanks,
Peter
>> How do you handle i18n in MapServer?
Dott. Peter Hopfgartner
R3 GIS Srl - GmbH
Via Johann Kravogl-Str. 2
I-39012 Meran/Merano (BZ)
Email: peter.hopfgartner at r3-gis.com
Tel. : +39 0473 494949
Fax : +39 0473 069902
www : http://www.r3-gis.com
