[mapserver-users] symbol problem
Valeria Muñoz
valemunoz at gmail.com
Mon Feb 9 12:26:12 EST 2009
hi david..
If i change the "OUTPUTFORMAT"configuration to:
OUTPUTFORMAT
NAME gif
DRIVER 'GD/GIF'
MIMETYPE 'image/gif'
#IMAGEMODE PC256
EXTENSION 'gif'
END
works... i thinks is a problem of AGG
RG
2009/2/9 Fawcett, David <David.Fawcett at state.mn.us>
> Valeria,
> It would be useful if you provided more information. What version of
> MapServer are you using? What were you expecting to see?
> Because you are setting your symbol angle to 0, I am guessing that you want
> all of the arrows to point to the top of the map.
> I am aware of a bug in AGG rendering where TrueType symbols are not
> corrrectly rotated (fixed in trunk), but I haven't seen a problem with
> pixmap symbols.
> In the symbol block of your layer, try commenting out the SIZE property. I
> think that you really just want your pixmap symbol to be displayed in its
> native size.
> Also, in your symbol definition at the end of your map file, try changing
> the value of GAP from -50 to 50.
> David.
> -----Original Message-----
> *From:* mapserver-users-bounces at lists.osgeo.org [mailto:
> mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *Valeria Muñoz
> *Sent:* Monday, February 09, 2009 6:39 AM
> *To:* mapserver-users
> *Subject:* [mapserver-users] symbol problem
> Hi
> I have problems with displaying symbols,I can not give the correct
> orientation-... do you know why does not work with this configuration?
> attached image of my problem
> OUTPUTFORMAT
> *NAME png
> DRIVER "AGG/PNG"*
> MIMETYPE "image/png"
> IMAGEMODE RGB #RGBA transparente
> EXTENSION "png"
> FORMATOPTION "TRANSPARENT=OFF"
> FORMATOPTION "INTERLACE=ON"
> END
> LAYER
> NAME 'calle'
> MAXSCALE 5000
> TYPE LINE
> DATA 'calle.shp'
> METADATA
> 'wms_title' 'calle'
> END
> STATUS DEFAULT
> TRANSPARENCY 100
> PROJECTION
> 'proj=longlat'
> 'ellps=WGS84'
> 'datum=WGS84'
> 'no_defs'
> END
> #LABELITEM 'ONEWAY'
> CLASS
> EXPRESSION ('[HWYLEVEL]' = '4' and '[ONEWAY]'='0')
> #TEXT (<->)
> #NAME 'calle'
> STYLE
> SYMBOL 'flecha_ambos'
> SIZE 13
> ANGLE 0
> #OUTLINECOLOR 161 189 196
> #COLOR 0 0 0
> END
> LABEL
> TYPE truetype
> FONT 'georgia'
> SIZE 6
> ANTIALIAS TRUE
> COLOR 156 0 0
> ANGLE FOLLOW
> #MINDISTANCE -1
> #MINFEATURESIZE -1
> OFFSET 5 0
> FORCE FALSE
> POSITION CC
> BUFFER 10
> PARTIALS FALSE
> END
> END
> END
> SYMBOL
> NAME "flecha_ambos"
> TYPE PIXMAP
> IMAGE
> "C:/ms4w/Apache/htdocs/mapFile/mapas/etc/icons/arrow_left_right.png"
> GAP -50
> END
> RG
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090209/d79c73c4/attachment.html
