[mapserver-users] symbol problem
Valeria Muñoz
valemunoz at gmail.com
Mon Feb 9 12:52:13 EST 2009
hi thomas
in december i did not use AGG/PNG configuration. now my problem is "AGG/PNG
RG
2009/2/9 thomas bonfort <thomas.bonfort at gmail.com>
> upgrading to 5.2.x should fix this.
> I'm surprised you're having this problem again as you posted the same
> message in december and noted that you had solved the problem.
> regards,
> thomas
> On Mon, Feb 9, 2009 at 18:34, Valeria Muñoz <valemunoz at gmail.com> wrote:
> > mapserver version is 5.0.2 .
> > RG
> > 2009/2/9 Fawcett, David <David.Fawcett at state.mn.us>
> >> Valeria,
> >> It would be useful if you provided more information. What version of
> >> MapServer are you using? What were you expecting to see?
> >> Because you are setting your symbol angle to 0, I am guessing that you
> >> want all of the arrows to point to the top of the map.
> >> I am aware of a bug in AGG rendering where TrueType symbols are not
> >> corrrectly rotated (fixed in trunk), but I haven't seen a problem with
> >> pixmap symbols.
> >> In the symbol block of your layer, try commenting out the SIZE property.
> >> I think that you really just want your pixmap symbol to be displayed in
> its
> >> native size.
> >> Also, in your symbol definition at the end of your map file, try
> changing
> >> the value of GAP from -50 to 50.
> >> David.
> >> -----Original Message-----
> >> From: mapserver-users-bounces at lists.osgeo.org
> >> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Valeria
> Muñoz
> >> Sent: Monday, February 09, 2009 6:39 AM
> >> To: mapserver-users
> >> Subject: [mapserver-users] symbol problem
> >> Hi
> >> I have problems with displaying symbols,I can not give the correct
> >> orientation-... do you know why does not work with this configuration?
> >> attached image of my problem
> >> OUTPUTFORMAT
> >> NAME png
> >> DRIVER "AGG/PNG"
> >> MIMETYPE "image/png"
> >> IMAGEMODE RGB #RGBA transparente
> >> EXTENSION "png"
> >> FORMATOPTION "TRANSPARENT=OFF"
> >> FORMATOPTION "INTERLACE=ON"
> >> END
> >> LAYER
> >> NAME 'calle'
> >> MAXSCALE 5000
> >> TYPE LINE
> >> DATA 'calle.shp'
> >> METADATA
> >> 'wms_title' 'calle'
> >> END
> >> STATUS DEFAULT
> >> TRANSPARENCY 100
> >> PROJECTION
> >> 'proj=longlat'
> >> 'ellps=WGS84'
> >> 'datum=WGS84'
> >> 'no_defs'
> >> END
> >> #LABELITEM 'ONEWAY'
> >> CLASS
> >> EXPRESSION ('[HWYLEVEL]' = '4' and '[ONEWAY]'='0')
> >> #TEXT (<->)
> >> #NAME 'calle'
> >> STYLE
> >> SYMBOL 'flecha_ambos'
> >> SIZE 13
> >> ANGLE 0
> >> #OUTLINECOLOR 161 189 196
> >> #COLOR 0 0 0
> >> END
> >> LABEL
> >> TYPE truetype
> >> FONT 'georgia'
> >> SIZE 6
> >> ANTIALIAS TRUE
> >> COLOR 156 0 0
> >> ANGLE FOLLOW
> >> #MINDISTANCE -1
> >> #MINFEATURESIZE -1
> >> OFFSET 5 0
> >> FORCE FALSE
> >> POSITION CC
> >> BUFFER 10
> >> PARTIALS FALSE
> >> END
> >> END
> >> END
> >> SYMBOL
> >> NAME "flecha_ambos"
> >> TYPE PIXMAP
> >> IMAGE
> >> "C:/ms4w/Apache/htdocs/mapFile/mapas/etc/icons/arrow_left_right.png"
> >> GAP -50
> >> END
> >> RG
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090209/2bf6d3a1/attachment.html
