[mapserver-users] How can I do a SQL text comparison in a mapfile?
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Feb 12 15:27:54 EST 2009
Just opened ticket:
http://trac.osgeo.org/mapserver/ticket/2888
add yourself to the CC if you are interested in tracking it.
-Steve W
Stephen Woodbridge wrote:
> Anyone know if we have a bug open for this issue. It seems like a pretty
> simple oversight that could be fixed in 5.4 if someone would champion it.
> -Steve
> Bob Basques wrote:
>> This was just talked about this past week in another thread.
>> I don't believe there is a method for escaping the internal quotes in
>> the SQL statement you show. Possible option(s) would be to add a
>> numeric column to the DB table/view for filtering on. Or make a call
>> that returns more using a different SQL filter and use EXPRESSIONs in
>> the Layer CLASS to filter further for display. This doesn't seem
>> like the economical way to do things things though.
>> There was some stuff done in recent versions of MapServer though in
>> EXPRESSIONs that may be related.
>> bobb
>>>>> Travis Kirstine <traviskirstine at gmail.com> 02/12/09 1:45 PM >>>
>> The following line does not work and I think it has something to do
>> with the single quotes. When I use double quotes Postgres thinks I'm
>> referring to a column name. Is there a way to escape the single
>> quotes? DATA "geom from (select id as oid, geom from some_table where
>> some_field = 'some_string') as myquery using SRID=-1"
>> The following line works because I'm doing a numeric comparison. DATA
>> some_field_number = 99) as myquery using SRID=-1"
> mapserver-users at lists.osgeo.org
