AW: [mapserver-users] Mapserver layer selects
Eichner, Andreas - SID-NLKM
Andreas.Eichner at sid.sachsen.de
Fri Feb 13 03:57:55 EST 2009
Altough this is more PostgreSQL/PostGIS related and should go to there
list but I tried it and...
strange, I can not reproduce your problem. This is what I did:
create table swip3 (
id int,
zname varchar(20),
pid int,
geom geometry,
rdate timestamp
insert into swip3 values ( 28, 'Zone 2', 607, geomfromewkb( decode(
'0101000020BB1000007ADFF8DA335161406551D845D17541C0', 'hex')),
'2009-02-12 13:30:00'::timestamp );
create table probe (
int id,
int logger_id
insert into probe values ( 607, 1 );
create table logger (
int id,
int client_id
insert into logger values ( 1, 120 );
SELECT * from swip3 WHERE (pid in (select probe.id from probe where
logger_id in (select id from logger where client_id=120)) and
rdate='2009-02-12 13:30:00') and (geom && setSRID( 'BOX3D(138.5356633
-34.9225467,138.5397151 -34.9184949)'::BOX3D,4283) );
id | zname | pid | geom
| rdate
28 | Zone 2 | 607 | 0101000020BB1000007ADFF8DA335161406551D845D17541C0
| 2009-02-12 13:30:00
(1 Zeile)
So I believe this has really nothing to do with MS.
