[mapserver-users] gmap-ms46 demo map not rendering properly
kapilmanoj kmanoj-pg7 at iiitmk.ac.in
Mon Feb 16 00:42:47 EST 2009
wow!!!!!!!!    its great!!!!!!!!      my gmap works fine.......  thank you
very much for immediate reply........
regards
kapilmanoj
Jeff McKenna wrote:
> kmanoj-pg7 kmanoj-pg7 wrote:
>> hello users...
>> I am a newbie  to mapserver. i am trying to get the gamp demo to run in
>> my
>> machine fedora 9. i have installed mapserver 5.0.3-3 and php-mapserver
>> 5.0.3-3 extension for php/mapscripting. Moreover i installed all the
>> libraries and packges whatever mentioned in the installation
>> documentation
>> perfectly.
>> i have added the AddTypes in the httpd.cong. Perhaps i have made the
>> edits
>> in the php.ini file. now when i call  the
>> http://localhost/gmap/gmap75.phtml
>> i stunned to see everything is projecting except the map is not
>> rendering.
>> at the beginning i thought it might be a problem of the java mode is
>> enabled
>> then i tried to disabled that but i failed it was also not working means
>> the
>> button was not working....  Then i looked into the httpd error log file
>> i got this following error............
>> [Wed Feb 11 15:06:53 2009] [error] [client 127.0.0.1] PHP Notice:
>> Undefined
>> variable: HTTP_POST_VARS in /var/www/html/gmap-ms46/
>> htdocs/gmap75.inc.php on
>> line 40, referer:
>> [Wed Feb 11 15:06:54 2009] [error] [client 127.0.0.1] PHP Notice:
>> Undefined
>> variable: HTTP_GET_VARS in /var/www/html/gmap-ms46/htdocs/gmap75.inc.php
>> on
>> line 42, referer:
>> [Wed Feb 11 15:06:54 2009] [error] [client 127.0.0.1] PHP Notice:  Use of
>> undefined constant MS_GIF - assumed 'MS_GIF' in
>> /var/www/html/gmap-ms46/htdocs/gmap75.inc.php on line 53, referer://
>> /var/www/html/gmap-ms46/htdocs/gmap75.inc.php on line 54, referer:
>> [Wed Feb 11 15:06:57 2009] [error] [client 127.0.0.1] PHP Notice:
>> Undefined
>> index:  MAP_NAME in /var/www/html/gmap-ms46/htdocs/gmap75.phtml on line
>> 589,
>> referer://
>> [Wed Feb 11 15:07:16 2009] [error] [client 127.0.0.1] File does not
>> exist:
>> /var/www/html/gmap-ms46/htdocs/netscape
> The GMap demo is very old and requires you to change your php.ini
> settings for error reporting to not show notices:
>     error_reporting = E_ALL & ~E_NOTICE
> -jeff
> Jeff McKenna
> FOSS4G Consulting and Training Services
> http://www.gatewaygeomatics.com/
> mapserver-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/gmap-ms46-demo-map-not-rendering-properly-tp2320776p2333307.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
