[mapserver-users] Problem with loading map file using C# map
script
Tamas Szekeres
szekerest at gmail.com
Tue Feb 17 18:33:14 EST 2009
Hmmm. I haven't found such an issue before.
If you could post an example that would be helpful to reproduce this.
Best regards,
Tamas
2009/2/18 Murty Maganti <MMaganti at oriongis.com>
> Hi
> I have a issue loading a map file through map script and need help.
> I have two map info (tab) files with same name but in two different
> folders. I have two map files each containing each layer. I am loading these
> map files using C# map script (each map file is loaded in to a separate
> mapObj on a separate thread). At run time, when I debug the second mapObj,
> the layer has items (layerObj.getItem()) from the first layer loaded by the
> first map file. I verified 'shapepath' on mapObj and it is pointing to
> correct path. There is nothing wrong there. I am surprised how is it caching
> the item info, just by the file name (file name is same but they are
> completely from different folders).
> When I load the map file one more time (again a different .Net thread, it
> shows up correct fields).
> Within my app (Asp.Net), I can consistently replicate this.
> Thanks
> Murty
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090218/521ce64f/attachment.html
